Quantcast Dual layer DVDs - SP mode is 4 hours? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > Blank Media
05-20-2009, 05:17 PM
from e-mail...
on dual layer dvds the sp mode is 4 hours right ? i tryed recording it on that speed and recorded only 2 hours can u tell me why please ?? i have a regular sony dvd vcr combo recorder please help ?
Although DVDs are advertised as being measured in "hours", it's mostly done to help transition people from VCRs to digital discs. A VHS tape was hard-wired to record certain pre-determined lengths, be it SP mode (2 hours), LP mode (4 hours), or EP / SLP modes (6 hours) -- on standard T120 tapes. Note that T130, T160, T180, T200, etc -- those were different recording times available.
A disc has no such limitations. Video is now nothing more than digital data, and the amount of data that can fit on a disc is solely determined by the bitrate used. DVD recorders have a number of preset "modes" named similar to VCRs -- XP (1 hour), SP (2 hour) -- and the LP, EP and SLP can pretty much mean whatever the DVD recorder manufacturer says it does, there is not any real consistency here. There are also some gooyf modes such as SP+, SPP, etc, and each length is determined by that manufacturer. In each case, refer to the machine's manual as to how many minutes or hours fit the mode. Some machines ever have "flexible" or "FR" (flex recording) modes, that let you specify how much you want on a disc in preset intervals (often 5 or 10 minutes).
If you're using a computer, there really isn't a "mode" or time limit/max.
If you're using a DVD recorder, then know that not all machines can use DVD+R DL media. And of those that can, it's usually pretty poorly implemented. Burning DVD+R DL media (or DVD-R DL media, for that matter) is not really suggested. For a DVD recorder, for the best experience, I suggest you stay with normal DVD-R and/or DVD+R for archiving. Only use DVD-RAM, DVD+RW or DVD-RW for temporary recordings.
Even if you're able to succesfully record to a DVD+R DL in a DVD recorder, odds are the the layer break won't be well understood by a normal DVD player, so you could only watch the disc in the recorder. Not a good scenario. Layer breaks are tricky animals, and recorders just don't handle it all that well. An infamous problem.
__________________
If this site has been as helpful as a book or magazine, then donate a few dollars or consider upgrading your membership.
You must be logged in to view images and download attachments.
TDK DVD+R 8X Dual Layer 15 Pack, $10, CANADACOMPUTERS.COM admin Blank Media, Drives - Coupons, Sales and Deals 0 07-01-2011 12:49 AM
Dual Layer Taiyo Yuden Dvds (inkjet printable), Where to buy? guokamoli Blank Media 5 06-01-2011 06:41 AM
Verbatim Dual layer - am i seeing things? manthing Blank Media 1 06-05-2008 12:24 AM
Dual Layer Discs - Which to get? ninjastriker Blank Media 6 10-04-2006 03:58 AM
Dual layer and double layer ndbs9u3 Blank Media 2 10-10-2005 03:34 PM
All times are GMT -5. The time now is 02:23 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
