Taiyo Yuden second choice to Verbatim DVD discs?
from email...
Verbatim media tends to be more compatible with players, the outcome of the highly reflective metal AZO dyes and quality MCC materials. Beyond that, yes, DVD-R is more compatible than DVD+R -- regardless of booktype/bitset being set to DVD+R or DVD-ROM -- although only marginally. It's more of an issue on players made prior to 2005. The quality of the media is honestly more important than format type. Taiyo Yuden has known problems with some DVD burners and players, and there have been quality issue with TY discs from time to time. Nothing major, but it would overall put the discs just under Mitsubishi/Verbatim. If I were grading the media, TY would get a solid "A" while Verbatim got an "A+". In other words, there's nothing wrong with TY media. It's good stuff. But another company just so happens to make something slightly better, according to the average experience. If TY works for you, don't change on our account. It's listed as a good disc, you're getting good results, and that's all that matters. |
I have bought Verbatim DVD-R whose Manufacturers ID shows that it is made by CMC Magnetics .The ID is CMCMAG-AM3 and I can not burn anything on these dvd's. I do not know what to do with these dvd's, My burner can burn Verbatim disc DVD-R ID MCC 03RG20.Can anyone help me.Can these be buned on any other burner Thanks in advance
You bought one of the new "Value Series" Verbatim branded discs, in a tape-wrapped package, if it has CMC as the ID --- not the Mitsubishi MCC DVD-R or DVD+R.
The only thing you can do with those CMC is give them away, return them to the store where they were bought, or throw them in the trash. CMC media is unreliable. Another burner probably won't help much, if you've already tried the discs, and they gave bad results. |
