After read previous threads in this forum about Identiftying DVD Manufacture and Media ID, I was very curious and decided to test several media using DVD identifier.
The result was quite accurate as you described, but I found there was very cheap DVD Media branded as Kachi and other not-too cheap media Mediatech displayed as manufactured by Mitsubishi..
I wonder if this is
fake Media ID or
probably just second-grade media from Mitsubishi
The reason I had my doubts because this media is very cheap, about 0.2 US$/pc while Mitsubishi around 0.3/pc
Here's my complete test:
Kachi-blue (blue means color of the front side/brand label)
Unique Disc Identifier : [DVD-R:MCC 03RG20 ]
Disc & Book Type : [DVD-R] - [DVD-R]
Manufacturer Name :
[Mitsubishi Chemical Corp.]
Manufacturer ID : [MCC 03RG20 ]
Blank Disc Capacity : [2,298,496 Sectors = 4.71 GB (4.38 GiB)]
** INFO : Hex Dump Of 'Media Code'-Block Listed Below
** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded
** INFO : Format 0Eh - Pre-Recorded Information In Lead-In
0000 : 01 40 c1 fd 9e d8 52 00 02 85 0d 0e 88 9a 80 00 .@....R.........
0010 : 03 4d 43 43 20 30 33 00 04 52 47 32 30 20 20 00 .MCC 03..RG20 .
0020 : 05 88 80 00 00 00 02 00 06 09 0b 14 87 78 90 00 .............x..
0030 : 07 88 80 00 00 00 00 00 08 08 13 0d 11 0c 08 00 ................
0040 : 09 95 07 0e 0b 78 88 00 0a a0 00 20 00 20 10 00 .....x..... . ..
0050 : 0b 06 1a 17 86 67 85 00 0c 99 ab 3a 83 20 32 00 .....g.....:. 2.
0060 : 0d 00 00 d0 00 00 00 00 00 00 ..........
** INFO : Hex Dump Of 'Control Data Zone'-Block Listed Below
** INFO : 4-Byte Header Preceding 'CDZ'-Block Discarded
** INFO : Format 10h - Physical Format Information Of Control Data Zone
0000 : 25 0f 02 00 00 03 00 00 00 26 12 7f 00 00 00 00 %........&......
[ DVD Identifier V5.2.0 -
http://DVD.Identifier.CDfreaks.com ]
Mitsubishi
Unique Disc Identifier : [DVD+R:MCC-004-000]
Disc & Book Type : [DVD+R] - [DVD+R]
Manufacturer Name : [Mitsubishi Chemical Corp.]
Manufacturer ID : [MCC]
Media Type ID : [004]
Product Revision : [Not Specified]
Blank Disc Capacity : [2,295,104 Sectors = 4.70 GB (4.38 GiB)]
Recording Speeds : [1x-2.4x , 4x , 6x-8x , 6x-16x]
** INFO : Format 11h (Method 1) - ADIP Information
0000 : a1 0f 02 00 00 03 00 00 00 26 05 3f 00 00 00 00 .........&.?....
0010 : 00 00 07 4d 43 43 00 00 00 00 00 30 30 34 00 38 ...MCC.....004.8
0020 : 23 54 37 12 02 54 6c 02 92 5f 15 15 0b 0b 08 08 #T7..Tl.._......
0030 : 01 19 1b 0c 0c 0c 0d 01 00 00 00 00 00 00 00 00 ................
0040 : 01 00 38 38 02 2c 5a 1a 05 2e 23 10 04 1e 1d 01 ..88.,Z...#.....
0050 : 00 00 02 2c 5a 1a 05 2e 23 10 04 1e 1d 01 00 00 ...,Z...#.......
0060 : 02 00 54 70 02 30 63 3c 24 14 0c 0c 01 20 00 00 ..Tp.0c<$.... ..
0070 : 00 00 02 40 66 42 24 14 0c 0c 01 20 00 00 00 2b ...@fB$.... ...+
0080 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00a0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00b0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00c0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00d0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00e0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00f0 : 00 00 00 00 00 00 00 00 ........
Blank
Unique Disc Identifier : [DVD+R:RITEK-R03-002]
Manufacturer Name : [Ritek Corp.]
Manufacturer ID : [RITEK]
Media Type ID : [R03]
Product Revision : [002]
Recording Speeds : [1x-2.4x , 4x , 6x-8x]
0010 : 00 00 03 52 49 54 45 4b 00 00 00 52 30 33 02 38 ...RITEK...R03.8
0020 : 23 54 37 09 00 3c 65 00 a0 5f 14 14 0a 0a 0a 0a #T7..<e.._......
0030 : 01 19 1b 0b 0b 0e 0f 01 00 00 00 00 00 00 00 00 ................
0040 : 01 00 38 38 00 25 62 3f 05 30 22 10 08 20 1c 01 ..88.%b?.0".. ..
0050 : 00 00 00 25 62 3f 05 30 22 10 08 20 1c 01 00 00 ...%b?.0".. ....
0060 : 02 00 54 70 00 4b 5d 64 1f 10 0a 0a 00 20 00 00 ..Tp.K]d..... ..
0070 : 00 00 00 64 5a 7c 1f 10 0a 0a 00 20 00 00 00 36 ...dZ|..... ...6
Maxell-gold => just like you said it isn't manufactured anymore by Maxell, but Ritek
Unique Disc Identifier : [DVD-R:RITEKF1]
Manufacturer ID : [RITEKF1]
0000 : 01 40 c1 fd 9e d8 52 00 02 87 0d 13 87 88 90 00 .@....R.........
0010 : 03 52 49 54 45 4b 46 00 04 31 00 00 00 00 00 00 .RITEKF..1......
0020 : 05 88 80 00 00 00 02 00 06 09 0f 15 87 88 90 00 ................
0030 : 07 a8 82 00 20 00 00 00 08 06 16 10 14 0f 0b 00 .... ...........
0040 : 09 94 07 0d 0b 88 88 00 0a 80 00 00 00 00 10 00 ................
0050 : 0b 09 1e 17 a7 89 85 00 0c b7 89 02 00 20 02 00 ............. ..
MATRIX/Mediatech-gold
Manufacturer Name :
BenQ - white
AXON016S]
Manufacturer Name : [Daxon Technology Inc.]
Manufacturer ID : [DAXON016S]
0000 : 01 40 c1 fd 9e d8 52 00 02 85 0e 10 87 88 80 00 .@....R.........
0010 : 03 44 41 58 4f 4e 30 00 04 31 36 53 00 00 00 00 .DAXON0..16S....
0020 : 05 88 80 00 00 00 01 00 06 09 0c 12 a8 88 90 00 ................
0030 : 07 88 80 00 00 00 00 00 08 06 16 0a 0e 09 04 00 ................
0040 : 09 98 06 0c 0b 70 88 00 0a 80 00 00 00 00 10 00 .....p..........
0050 : 0b 08 16 18 97 88 75 00 0c b7 9b b8 83 00 30 00 ......u.......0.
0060 : 0d 0f ff d0 00 00 00 00 00 00 ..........
TDK-gold
Unique Disc Identifier : [DVD-R:CMC MAG. AM3]
Manufacturer Name : [CMC Magnetics Corp.]
Manufacturer ID : [CMC MAG. AM3]
0000 : 01 40 c1 fd 9e d8 52 00 02 84 0d 12 98 99 90 00 .@....R.........
0010 : 03 43 4d 43 20 4d 41 00 04 47 2e 20 41 4d 33 00 .CMC MA..G. AM3.
0020 : 05 88 80 00 00 00 02 00 06 09 0d 14 98 88 90 00 ................
0030 : 07 88 80 00 00 00 00 00 08 07 17 0a 0e 09 04 00 ................
0040 : 09 95 07 0d 0b 88 88 00 0a 80 00 00 00 00 10 00 ................
0050 : 0b 06 17 15 b8 99 85 00 0c b8 9a 32 03 20 32 00 ...........2. 2.
GT Pro-white => this one is quite good, many people use it in my country despite made by CMC Magnetics
I wonder if there's good explanation about this..thx..
