Quantcast Please make some DVD and CD poly case templates - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > Blank Media
06-21-2010, 03:06 AM
continued from PM...
Remember to ask all tech questions in the forum. If sending personal comments via PM, try to separate tech questions out of it. Otherwise it can take a while for adequate response. Thanks!
Originally Posted by dyfan
Thanks for writing, good to hear from you again!
About the poly case template (in a "CD" size) that I've been begging you left, right and center for...SMS has a listing for both a '5.2mm' size and a '10.4mm' size- both of which they call "slim"...
http://www.supermediastore.com/produ...=50&filter=all
http://www.supermediastore.com/produ...ax=15&offset=0
As near as I can tell, I think these are the same...The site may have altered the part number? This is the type/size case that I am hoping you have templates for, in spine sizes corresponding to however many discs the poly (and not hard-plastic, hinged jewel) case holds?? Like I was saying, I'd like to make a slide-in insert to use for projects that are presented across 2 discs, instead of just one (which I routinely just use a hard plastic jewel case for).
Please consider this and let me know, okay? If you don't have anything, please let me know that, too...I have a few projects that I had to put on ice because you said you'd upload case templates 'in a few days'...
Hope you're doing good, hear from you soon.
Yeah, a few days was extended into a much larger project for the site, involving case artwork.
I have your sample cases, and massive expansions to the DVD and CD case options will happen in July or August. Several of us are working on some excellent cases, based off designs we've used professional in the past.
These will all be for Photoshop, and should be easy to use.
It just takes time to put it all together.
Do me a favor and reply to this post. (Even just saying "Thanks" will work.)
This way, I'll get the system notifications to keep this question logged in the "to-do" queue.
Thanks.
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
06-21-2010, 12:14 PM
dyfan's Avatar
dyfan dyfan is offline
http://www.digitalfaq.com/forum/show...twork-430.html
07-04-2010, 05:52 AM
meetless meetless is offline
thanks this is something i need also
07-07-2010, 11:22 PM
Feel free to describe something you might like to see.
Or give examples of cases (in part or in whole) that you like from commercial DVD releases. Just link to the Amazon page for the DVD, so I can see it. Mention that you like the whole case, or mention a piece of something you like. For example "I like the partially transparent box on the front".
I know what I like, and that's what will be made (at first) for the site downloads. But beyond that, I want to make cases that others like too! So shoot in those suggestions.
Look for the first cases to start appearing in August and September -- just in time for football season. (All those school organizations need DVD cases, too!)
__________________
DVD Case Artwork Blank Templates for Photoshop [DOWNLOADS] admin Blank Media 19 10-10-2010 05:33 PM
Dvd case - all the same? manthing Project Planning, Workflows 2 03-15-2010 04:13 AM
E-mail newsletter HTML templates [NOTES] admin Web/Print Design & Planning 0 08-11-2009 12:44 AM
Spindle vs. Amaray case (vs. CD jewel case?) Reading Bug Blank Media 5 05-12-2009 07:37 PM
More DVD case templates for download wayshway Blank Media 2 03-14-2009 06:15 PM
All times are GMT -5. The time now is 04:53 AM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
