12-26-2005, 12:49 PM
d.smyth d.smyth is offline
{DV 3281} Datawrite Red (8x) DVD-R in Spindle Tubs of 50
ADVInfo: TTG02
are these the 1st class dvds ???
just want to make sure before i buy alot of them.
12-26-2005, 02:26 PM
All you must do is refer to the media ID list at http://www.nomorecoasters.com
12-26-2005, 05:14 PM
TTG is a TDK ID.
MBI is a Moser Bauer ID.
You want FIRST CLASS discs most.
You can do SECOND CLASS discs if needed.
Third and Fourth class is never suggested. Never.
Be sure to use a brand that is not using FAKE media IDs.
This is where brand becomes important.
12-27-2005, 05:48 AM
ADVInfo: TTG02
.... those should be good discs, assuming your burner cooperates.
Burning media can be burner dependant sometimes, as some burners do not support some media as they should. Keeping updated firmware is something that can be done too, when needed.
Also, don't go back and edit posts. When you ask a question, leave it. If you have more, use the reply feature and ask more. Other people can learn from your posts, that's part of the archival value of a forum, to see what others have said in the past.
