Quantcast Problems with 8x Apple DVD-R - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > Blank Media
09-01-2010, 12:42 AM
continued from email...
Please try to post all tech questions in the forums. Thanks!
Is there any known problems with Apple 4.7GB 8X DVD-R media? I have a customer who has made two complete backups using this Apple media - that's two sets of 83 discs (each set) for a total of 166 discs. As of three weeks ago, none of the discs are readable - as every Mac in the office ejects them out shortly after loading. Is there a way to access the data on the discs? Thanks for reading my questions about the Apple DVD-R media.
Welcome to the site.
No, there are no known problems with 8x Apple DVD-R.
Do you happen to know what the media IDs are for these discs?
See Software for Media ID and Quality Scans [DOWNLOADS + GUIDE]
Before I get to ahead of myself, let's see what blanks we're dealing with here.
Register for the forum, reply with your answer.
Thanks.
__________________
If this site has been as helpful as a book or magazine, then donate a few dollars or consider upgrading your membership.
You must be logged in to view images and download attachments.
09-01-2010, 02:50 AM
highlander11 highlander11 is offline
if the dvd burner worked while burning and you ( the email guy) used a normal burning software its a problem in his dvd drive or software issues( which I dont think it is a software issue)
166 dics for a drive in a week lets say or even in a day is a lot.
some will say: so why did we buy a burner -to backup
but some cant handle 166 discs or dvds lol
the dvds media are fine much better then mine lol so its not a problem of media
I think the "eye" of burning ..died
I burned 150 dvds in 5 years then I had the same problem
but still we live in different areas so maby its not your case although most of the stuff are amde at the same place (depends on the company od dvd burners)
Apple iPad? More like the iDontCare kpmedia Digital Devices 9 10-05-2010 11:51 AM
All times are GMT -5. The time now is 03:34 AM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
