-   Blank Media (https://www.digitalfaq.com/forum/media/)
-   -   Lost caps to thumb drives, is this a big deal if USB end is exposed? (https://www.digitalfaq.com/forum/media/2945-lost-caps-thumb.html)
Sossity 03-11-2011 04:40 AM
This where those turtleing ones have an advantage, but I like the regular ones, they are easier to insert into a usb port, but I lost the cap on one the other day, will it harm the thumb drive if the usb part is not covered by a cap? I carry them on my key chain.
admin 03-11-2011 01:27 PM
Only insofar as you allow dirt, lint, grit and other foreign matter to hide away in the USB port. You could always cover it over with a piece of Scotch tape if you're really worried. Remove and replace, as needed.
It really depends more on how clean you and your clothes are. A kid, for example, would probably have mud caked in it after a day. A businessman in a suit would have no more threat the lint from a coat pocket. If your keys are stored in a purse (or that camera bag), then it could be perfectly fine, and there's absolutely nothing to worry about.
My drives sit open almost 24/7, because they never move much out of the office.
