Blank Blu-Ray media recommendations
Looking for general recommendations.
For Verbatim are your experiences good? Do I need to look out for media manufactured in a specific place like for their DVD's? Thanks! |
In general, it's identical to DVD media. Or more specifically, to DVD+R DL media --- Use Verbatim, and only Verbatim.
The LTH discs (low-to-high) sub-format Blu-ray recordable discs can vary in quality, based on your BD-R burner. Those discs came later to market, having found a way to be produced with organic dyes and materials similar to DVD. You really need a newer burner (say mid 2010 or later?), and with recent firmware. The "regular" non-LTH BD-R discs work fine in pretty much any burner. But again, newer burners may be a little better than the earlier generation ones. As expected, Amazon seems to have the best prices on Verbatim Blu-ray blank discs:
That's my advice to you, for buying the best blank BD-R, which will give your the fewest coasters and lowest number of blank Blu-ray burning problems. |
