Originally Posted by gamemaniaco
1) In my DVD Mdisc Verbatim is written 4x and in my DVD-R Verbatim AZO is written 16x, which speed is the best for them and which free software burns to use for being the best?
Write a 4x disc at 4x.
The 16x at 12x, 8x, or 4x. 12x best, then 8, then 4 last choice.
2) In total I own the burned mdisc and verbatim dvds and the mdisc and verbatim azo dvds not burned (In pin) after 15 years all of them burned and unburned (in pin) will be discarded bad and throw in the trash and buy new optical discs?
I see no reason to trash a good disc simply because it might be aging, but whatever. I've already explained this to you, not doing it again.
3) Is it possible to store the discs in big plastic boxes or another container to protect from moisture and prolong the life of the discs for more than 15 years?
No.
