Rodisc DVD+R DL media ID?
I would like disc identification on Rodisc DVD+R DLs.
This is why: I bought a pack of dual layer discs, branded by Rodisc, in a Factory Direct store. I must have tried five of those discs and all were bad burns. Took them back and requested another brand: Databyte. Same thing happened. Returned them and got a refund. This problem was pretty unique, if you will, as both my old colmputer's Benq DW1620 and the Matsushita drive on my mother's laptop rejected discs from both brands. I know Databyte has a stinky reputation as it is made from Ume. But what of Rodisc (and no, it's not Prodisc; the P is missing)? What is the disc ID? Thank you for your help in advance. EDIT: I would like to add that the drives perform exceptionally when reading DVD+R DL discs (or DVD-9) and burning/reading DVD-R/+R discs, so I would expect that the drives have no errors in that respect. |
Being that it's also a no-name brand, I'd not be surprised if it was also UMEDISC junk.
The only way to know for sure is to check the media ID. |
Thanks, lordsmurf.
By the way, how do I edit my posts? I am sorry that I made a double post. EDIT: Ah, never mind. |
All right guys, are the Verbatim AZOs the superior model of all other Verbatim series? I'm wondering because I didn't catch a mention of AZOs.
However, I will be sorry if I overlooked one. Thanks. |
Yes. Only Verbatim AZO discs (SL and DL) which are manufactured by CMC Magnetics using AZO dyes to Verbatim specs.
Beware as Verbatim is packaging non-AZO discs in packaging almost exactly the same as AZO. Read this thread I posted at videohelp.com to help spot the difference: https://forum.videohelp.com/threads/...-AZO-packaging |
I hate to sound ignorant, but it seems that it was pretty easy to spot false AZO packaging: the blue and orange, or the ones that have either the words "Life" or "Value," right?
If I'm wrong, just tell me I'm stupid. Thanks for the heads up though. EDIT: This is what I have in mind: https://www.canadacomputers.com/prod...item_id=041213 |
Yes, make sure it has the AZO logo somewhere on the label and make sure whomever you buy it from takes returns if it's non-AZO as they may have made an honest mistake and mistaken the orange or purple Life Series packaging for AZO discs.
Years ago, when the Life Series first came out, they were stocked on store shelves right next to the remaining AZO stock and shared the same SKU in the stores system. I used to see OfficeMax and Office Depot ads showing the AZO packaging in their ads, but when you got to the store, all they had was the then new blue and white Life Series packages. As far as anyone in the store was concerned, it was just different packaging. |
Well, I'm only interested in getting Dual Layer discs and from Verbatim's AZO series, which are much-touted by many users online.
There seems to be only one form of dual layer Verbatim DVDs, and that's the one I linked, but I could be wrong. If I'm wrong though, it looks like I'm screwed. EDIT: Just checked out the store I linked the product information from, there appears to be many variations of Verbatim's DVD+R DL products. I'm screwed. Oh well, there seems to be only one AZO DVD+R DL package and not diluted with other packs like AZO Data Life or AZO Life Series. I'll be extra careful. |
1 Attachment(s)
Yes, there is only one Verbatim AZO DL disc, the DVD+R DL you've linked to. To clarify, Verbatim is the brand name. AZO is the dye formulation proprietary to Verbatim and only discs that use that dye formulation will be have the AZO logo as shown here: http://www.digitalfaq.com/forum/error.gif Verbatim has made it harder by packaging their generic (i.e. poor quality CMC manufactured disc) Life Series in the same purple and orange packaging as the original Verbatim discs, which were all AZO until about 10-12 years ago. They've also shrunk the AZO logo (as shown on my link above) to make it harder to spot. The DataLifePlus series is reportedly still AZO, but not worth the chance if you don't see the AZO logo on the packaging. |
Also, use Imgburn for burning your discs and allow it to determine the layer break for maximum compatibility and chance of success (which isn't 100% with DL discs).
Thanks, lingyi, for everything.
You are very helpful. |
