09-16-2019, 09:28 AM
Ryelzz Ryelzz is offline
Hi All
I have converted a number of tapes and have not seen this issue present itself.
Capturing with a PAL VHS player with NTSC playback support -- > DMR-ES15 --> Hauppauge USB 2 -->OBS
To me, the playback looks like it wants the capture card to be set to NTSC, but whenever I try and change the capture card input settings, it always reverts back to PAL B. I am assuming these PAL VHS players do not output NTSC but convert NTSC to PAL output. You input would be appreciated.I am in Australia so PAL is standard.
I am thinking I will need to procure a NTSC native VHS player, that outputs NTSC.
09-16-2019, 10:25 AM
Yeah that looks like NTSC being captured as PAL.
PAL decks playing NTSC typically output PAL60 - NTSC with PAL-encoded colour, some can also do NTSC 4.43 - NTSC with the colour at the PAL color frequency.
I know the European DMR-ES10 and I think other Panasonics as well support NTSC input. This manual suggests the models in Australia/middle east have the same capability. You will then have to change TV system from PAL to NTSC in the menu. I know at least the ES10 does not work with PAL60 though, something I have tested, not sure about NTSC 4.43 (have yet to test that). I have used it with a multi-system VCR which output normal NTSC so I know the TBC worked on that. (Though on both PAL and NTSC it can clip whites a bit.) You would also have to set the capture card to NTSC afterwards.
I think the capture card itself would support PAL60, though without the DVDR in the chain you would get wiggling and instability instead. (Built-in Line-TBCs are typicaly disabled in NTSC playback on PAL decks.)
An native NTSC-capable deck may be needed here yea. Alternatively, the European Pioneer (DVR-430 and higher second number) and Sony DVRs (RDR-HX 750 and higher second number, and most likely the equivialent DVD-only RDR-GX models) do handle PAL60, though they TBC in them is not as capable as the panasonic one. Looks like the oceanian ones can do this as well judging by the manual.
VHS audio issue Y4BB Restore, Filter, Improve Quality 1 05-20-2018 08:28 AM
VHS capture with SDI issue cerestan Capture, Record, Transfer 6 10-12-2015 01:20 PM
MP3 gain issue - need help manthing Videography: Cameras, TVs and Players 2 03-04-2011 09:28 AM
NTSC & PAL issue for Blu-ray? admin Videography: Cameras, TVs and Players 1 09-01-2010 01:52 AM
DVD creating issue SavageAmusement Capture, Record, Transfer 9 05-03-2006 06:21 AM
