12-05-2019, 07:44 PM
nicholasserra nicholasserra is offline
Sorry for confusing title. After having a couple seized 8mm tapes snap their film inside my camera, I want to start confirming old tapes are not "stuck" in a gentle way before trying to play them. In my mind I want some kind of small plate with adjustable gears and a small crank where I can place an 8mm (or other) tape, and hand crank through to beginning and end to make sure the film is intact. Then if stuck I know I need to bake it or do a repair.
Anything like this exist? If not i'm about to start 3d modeling and prototyping.
12-05-2019, 11:32 PM
BW37 BW37 is offline
You might find this useful for ideas:
https://www.youtube.com/watch?v=8IbpKwGfu74
Hopefully, I've got this right and the link works
12-07-2019, 01:37 PM
josem84 josem84 is offline
It's moisture/mold what causes your tapes to stick together and eventually break. The transport mechanism within your camera is actually more gentle on the tapes than those rewinders. Most 8mm tape rewinders are pretty tough on tapes.
Safest way to go is doing it by hand. Or if you're kind of a DIYer, you can build your own device making sure to apply the right amount of force on the tape.
A few hours on a food dehydrator at low temperature wouldn't hurt either.
Panasonic NV-HS830 VCR doesn't wind tape back in? gutt3d Video Hardware Repair 2 12-23-2017 06:25 AM
JVC BR-8600U won't play tape, fast forward, rewind? Dead Christmas Video Hardware Repair 2 05-07-2016 07:31 AM
Does Optodisc still exist? pepst Blank Media 1 07-17-2013 09:25 PM
Uncompressed MOV? Does it exist? metaleonid Encode, Convert for discs 5 06-19-2012 09:56 AM
