12-13-2011, 03:09 PM
Scientists at MIT have created an imaging system ("video camera") capable of recording light itself, with a frame rate of around one trillion frames per second. The one question I kept asking was never answered in any article: How fast is the hard drive write speed? Or more likely, some kind of uber solid-state drive. Trying to capture 60fps is hard enough, but 1,000,000,000fps?!
Originally Posted by excerpt from MIT.edu press release
MIT researchers have created a new imaging system that can acquire visual data at a rate of one trillion exposures per second. That’s fast enough to produce a slow-motion video of a burst of light traveling the length of a one-liter bottle, bouncing off the cap and reflecting back to the bottle’s bottom.
Media Lab postdoc Andreas Velten, one of the system’s developers, calls it the “ultimate” in slow motion: “There’s nothing in the universe that looks fast to this camera,” he says.
The system relies on a recent technology called a streak camera, deployed in a totally unexpected way. The aperture of the streak camera is a narrow slit. Particles of light — photons — enter the camera through the slit and pass through an electric field that deflects them in a direction perpendicular to the slit. Because the electric field is changing very rapidly, it deflects late-arriving photons more than it does early-arriving ones.
The image produced by the camera is thus two-dimensional, but only one of the dimensions — the one corresponding to the direction of the slit — is spatial. The other dimension, corresponding to the degree of deflection, is time. The image thus represents the time of arrival of photons passing through a one-dimensional slice of space.
The camera was intended for use in experiments where light passes through or is emitted by a chemical sample. Since chemists are chiefly interested in the wavelengths of light that a sample absorbs, or in how the intensity of the emitted light changes over time, the fact that the camera registers only one spatial dimension is irrelevant.
But it’s a serious drawback in a video camera. To produce their super-slow-mo videos, Velten, Media Lab Associate Professor Ramesh Raskar and Moungi Bawendi, the Lester Wolfe Professor of Chemistry, must perform the same experiment — such as passing a light pulse through a bottle — over and over, continually repositioning the streak camera to gradually build up a two-dimensional image. Synchronizing the camera and the laser that generates the pulse, so that the timing of every exposure is the same, requires a battery of sophisticated optical equipment and exquisite mechanical control. It takes only a nanosecond — a billionth of a second — for light to scatter through a bottle, but it takes about an hour to collect all the data necessary for the final video. For that reason, Raskar calls the new system “the world’s slowest fastest camera.”
Full story at http://web.mit.edu/newsoffice/2011/t...mera-1213.html
Compression with MMC ATI, P frames and B frames for MPEG-2 ? John Capture, Record, Transfer 1 08-20-2011 10:15 PM
Best and simplest camcorder or video camera for shooting video? Sossity Videography: Cameras, TVs and Players 13 12-26-2010 11:09 AM
Problem with MPEG video dropping frames kabal2000 Capture, Record, Transfer 9 08-02-2010 12:39 AM
Video camera recommendations, for 2009 and later? Theresa Videography: Cameras, TVs and Players 4 05-30-2009 01:41 AM
Need to get a video camera segen77 Videography: Cameras, TVs and Players 3 02-24-2009 10:26 PM
