08-18-2015, 07:35 PM
pdrny pdrny is offline
I recently got a Denon DVD-2200 (US model)
When playing region 1 NTSC DVD's the picture looks fine.
When playing PAL DVD's the picture is shifted to the bottom of the screen so much it cuts off the bottom of a widescreen movie.
The same problem shows up through component and composite outputs, and on two different monitors.
The PAL DVD plays fine on my Pioneer DV-588A.
This is both before and after applying the firmware lordsmurf links to.
Has anyone else had this problem?
Any suggestions?
08-19-2015, 02:02 AM
There are several ways that NTSC players can choose to playback PAL.
- One of the worst methods adds geometric distortion.
- Another terrible method deinterlaces.
- Yet another just adds ghosted frames.
The best DVD player method adds ~5 frames, without changing audio. The motion is somewhat less smooth, but it's better than screwing up the geometry, the interlacing, or adding ghosting.
The ideal PAL > NTSC method requires Avisynth, or a similar method. Rip the disc, convert, re-author. Of course, this takes time, and may not be worse it just to watch a movie.
The Denon just uses subpar conversion, it seems. Many "no name" players are like this. Only some of the higher-end (and higher-priced) players from Pioneer, Toshiba, Sony, Samsung, etc, tend to use the better methods. At this late date, DVD players are out, and Blu-ray players are in. The Samsung, for example, cannot player a PAL disc, but a PAL video streamed to it plays flawlessly.
08-19-2015, 04:21 AM
Thanks.
I'm surprised the Denon uses subpar conversion since it would have cost more than the Pioneer when new.
Panasonic NV HS960 playback problems cybergtooth Video Hardware Repair 20 01-05-2015 02:12 PM
Denon DVD-2200 - DVD player hack lordsmurf Videography: Cameras, TVs and Players 8 09-14-2012 12:07 PM
Image playback problems Hampton80 Videography: Cameras, TVs and Players 4 12-02-2010 12:15 AM
DVD Playback Standalone Player Problems emsdallas Videography: Cameras, TVs and Players 1 05-16-2010 05:01 PM
8mm playback problems, tracking and audio issues admin Capture, Record, Transfer 0 10-08-2009 09:03 PM
