-   General Discussion (https://www.digitalfaq.com/forum/news/)
-   -   VHS digitization: chroma noise clean up? (https://www.digitalfaq.com/forum/news/7289-vhs-digitization-chroma.html)
Tafflad 04-16-2016 02:04 PM
2 Attachment(s)
Have been capturing all the families VHS tapes .... luckily most are on SVHS PAL so a little better than standard VHS.
Understand there is usually a need to improve noise & always a need to attend to Chroma noise ......... have come across a few scripts (such as example attached)
These use Cnr2 filter to correct chroma noise.
Looked at your 'Avisynth MultiScript' (is that the latest ver 5-10-2014)
For example you use Cnr2:
Cnr2("xoo",4,2,64) # remove chroma banding noise, wide UV setting
I had read in a few places that CCD_1.7 (Color Camcorder Denoise) is better, and while asking around was given the following comment:
"Lordsmurf fome DigitalFAQ says that CCD is more effective than CNR2"
Have you carried out any side by side comparison of Cnr2 and CCD ? ......... be keen to have your views, and if it has better performance, any tips on what settings / how to use it.
In case it's relevant for your response .... typical workflow for my videos destined for streaming sites is:
DV capture of 720 x 576 interlaced PAL
Loaded into Vegas and rough edit to remove unwanted video
Denoise with script attached
Deinterlaced using QTMG scipt & spline resized
Use VD Stabilize with DeShaker (if required) & sharpen
Loaded back into Vegas for final edit - transition, titles, colour correction, etc.
Audio dealt with in Soundforge
Render out as 960x720p, 50
(use MagicYUV for intermediate lossless versions)
For non-streaming sites would leave out deinterlacing step, and do resize in Vegas.
themaster1 04-16-2016 06:34 PM
CCD is great for normal chroma noise with moderate settings, between 5-15 for commercial tapes.
You can do better in your workflow if you use the avisynth virtual file you make your script with qtgmc etc.. , create a fake .avi (u'll need a converttorgb24 at the end of your script) and you're ready to roll in sony vegas (it'll be slow though)
Tafflad 04-17-2016 01:45 PM
"the avisynth virtual file you make your script with qtgmc etc.. , create a fake .avi "
I don't understand this, care to expand on the steps and what benefit it brings ?
Currently after each VD/AVIsynth step I save as MAGICYUV .. as an intermediate lossles.
lordsmurf 04-17-2016 05:30 PM
CCD (Camcorder Color Denoise 1.6/1.7) is more effective than CNR2 (Avisynth) or Chroma NR (VirtualDub).
CCD works more on the in-picture visual issues.
CNR and CNR2 work more on the global level, not really aware of the picture.
I use CCD most, sometimes C-NR. I rarely use CNR2.
It's based on many tests, yes. I need to note this in my MultiScript. In fact, I've added on it quite a bit this year, and I don't think I've uploaded a new one since 2015. I've been working heavily on the site backend (new glossary coming soon!), and projects, so not much time for forum use lately.
- DV not relevant.
- Remove chroma noise before giving it to the NLE (due to RGB conversion)
Attaching scripts is great, but also put them in [code][/code] bbcode for me. Do both. I always do. Or at least try to. That saves me time.
Off-topic: Shot DV doesn't often have bad chroma noise. But then again, it depends on the sensor. I really liked Canon ZR (DiGiC chipset) series because it held down noise very well.
