05-11-2016, 10:56 AM
internetmissouri internetmissouri is offline
I switched to Open DNS as KP Media suggested- phenomenal speed jump 5 mps to 30 on charter!
But smart phones, pads and TV will not hook up.
Connection is there, but no internet, what am I missing?
Thanks,
05-16-2016, 08:17 AM
Computers are wireless devices generally use a default of whatever the router has set. You can easily change a computer to use a different DNS, but wireless devices (smart phones, iPads, video games, etc) generally have the option blocked. You can often do it on hacked/jailbroken devices, but many of us don't want to do that.
Simple fix: Change the router and/or modem.
Then all communication is forced through OpenDNS.
05-16-2016, 08:39 AM
Thanks,
I did switch Cisco linksys EA3500 wireless to open DNS, using first 3 addresses.
Modem is Charter provide Cisco dpc3010.
Laptops accepted these but smart items see connection but don't link up.
When I switch back to old connection, all connect back a slow speed.
Do you have a router to recommend?
How to watch Youtube videos without buffering? OpenDNS? mgbkayak General Discussion 1 08-03-2015 04:26 PM
Best Capture Devices for VHS to DVD Zoink187 Capture, Record, Transfer 5 02-17-2014 07:48 AM
Which devices can be plugged into a USB hub? Which ones cannot? Sossity Computers 3 07-19-2012 06:02 AM
EasyCap vs ATI 600 for USB capture devices? sChen77 Capture, Record, Transfer 8 07-19-2012 02:42 AM
Capturing Devices other than Cards ishmot Capture, Record, Transfer 4 04-07-2005 05:02 PM
