Hi
im not sure if this is the right place for this question but ill try my luck
im looking for a way to output 2 different video sources from my pc via RGB (bnc) into a fairlight CVI then process them and send the video via RGB (bnc) back to the pc and capture it.
ive been doing it for a while using HDMI to composite from pc into the fairlight and back to Elgato capture stick but i understand that using the RGB connections will give me a much better quality.
ive read anything i could find on the subject but im not sure what would be the ultimate setup to get the best results out of the fairlight.
tnx so much in advance.
