10-07-2017, 01:06 AM
Thanks Lordsmurf
Your input is very much appreciated.
I'm learning a lot about the DirectX interfaces and how they "morphed" them from 9 to 10 and 11.
I can see how they "might" have left DirectX10 alone if you upgraded to Win7 and not installed DirectX11 which was the native version of DirectX for Win7.
DX11 is the real problem.. its "not finished" and never will be.. they burned some bridges with the past and then retired the people working on it. .. could be that's why it appeared more stable.. they burned bridges.
The real symptom was the ProcAmp was no longer able to build its controls with the old driver, they imposed new minimal interface standards on drivers and disabled ProcAmp controls if the driver didn't meet them. I believe that is why the MMC stopped working in Win7 until much later versions recompiled to support the new requirements for DX11.
Vista deliberately doubled the interfaces and detected if the new standards were not met.. it was designed to support the old DXVA standards. Instead of "breaking" older apps, it adapted and let you use the older interface.
I am not sure how to deliberately hold on to DX10 with an upgrade.. or deliberately retro-grade DX11 to DX10 so that support comes back.. but if you've done it once.. then there is hope.
It might be as simple as regsvr32 a DLL that holds that particular interface, a COM browser might be able to find it.. I just don't know. Video Capture interfaces should be confined to a particular DLL.. but I don't know which one.
As for x64 support.. i still hope its just an INF mystery to solve somewhere down the road. The drivers should be user space mini-drivers communicating over the ksproxy and bus drivers that come with windows.. if they didn't fiddle with those interfaces.. then hooking them up with a modified INF may work. But I'm not thinking seriously in those directions yet.. one reason I think this.. is I read about a Kodak USB scanner, in which a person did that exact thing.. they took the 32 bit drivers and INF file.. edited a tiny bit.. and they bonded with the ksproxy and usb drivers on 64 bit OS and reported that it worked.. sounds like a fishy story.. but its barely believable.
I doubt a PCI driver would be as flexible as a USB driver.. but who knows.
Huh.. I think XP came with DX8 and DX9 was an upgrade (or that could have been W2K) .. point is.. the next version of DX is usually offered as an "upgrade" on the previous generation OS.
So Vista at some point would have had an "upgrade" from DX10 to DX11 if you accepted that upgrade.. then logically MMC would have stopped working. Any random Windows Update before after or during migration from Vista to Win7 could have upgraded from DX10 to DX11 and sabotaged the effort.
Its a thought.. perhaps upgrading only "offline" would be safe.
10-07-2017, 09:50 PM
Nice !
Lordsmurf thank you.
It took a lot of twists and turns, applying a Vista SP1 service pack, and patiently waiting for an Enterprise to Enterprise Upgrade from Vista to Windows 7.
But it worked!
The ATI TV Wonder USB 2.0n cdrom software using the XP 32 bit drivers and the ATI MMC 9.08 TV Apps with Video Soap (are) running under Windows 7 Enterprise Edition x86 (32 bit).
I was concerned about the Video Proc Amp no longer having control over the things it normally allows you to slide back and forth.. and that is still the case. DirectX apparently did change that interface and the upgrade disabled it.. so DirectX reliant programs may find it hard to use these drivers and software natively.. for those.. I would recommend going back to XP or Vista, where the Video Proc Amp controls are still fully functional.
But the controls [built-in] to the MMC that control much the same things, like brightness, contrast, tint, ect.. all still work.. even if DirectX doesn't support them with these 32 bit drivers.
Its an [odd] combination.. I would have thought MMC would be [totally] DirectX dependent.. but apparently that is not the case.. and MMC talks directly to the device over USB.
There was no predicting this outcome.. it was completely unexpected.. only Lordsmurf's previous experience and dedication lead to this confirmation.
[To recap]
You (can not) install from the cdrom that comes with the ATI TV Wonder USB2.0n device directly to Windows 7 x86
1. many of the Installshield 9 installers simply fail and must be run in comptaibility mode with XP SP2
(XP SP3 mode fails, in weird ways.. don't even try it.. double check.. Vista and Win7 pick different XP SPx versions by default)
2. even after you do install, the ATI TV App will inform you it cannot initialize the video from the capture device (frustratingly so)
3. BUT you absolutely [can] install the cdrom software on XP SP2, and you can install the cdrom software on Vista SP0 (with a lot of preparation and installing using compatibility mode for every app on the cdrom) [THEN] you can apply Vista SP1 and then upgrade that to Windows 7.. the installed software will automatically be migrated and "continue" to work.
(The Upgrade from Vista to Windows 7, requires Vista SP1 be installed, so you cannot by-pass this step.)
I can't prove it yet.. but fundamentally this means it must be an installer issue on Windows 7.
The InstallShield software that was used to create these packages (version 9) is one of the most difficult types, it is a combination InstallShield Script and Microsoft MSI hybrid.. which was very prone to failure based on historical research. It was basically "morphing" the install based on os type, os version, and hardware requirements.. a perfect storm for the most error prone installation imaginable.
Better would have been separate install packages for each os type and os version and explicitly documented hardware requirements.. but that is the past.
Windows 8 broke the upgrade path, so there is not a clear path to Windows 10.
A perhaps more productive path would be to use WinINSTALL LE or InstallShield Repackager to re-compose an installer from before and after shots on a working system (in this case probably Vista x86) and then try those on Windows 7 and possibly Windows 10
I'm currently performing a Macrium backup of the working Windows 7 x86 system with the ATI software installed to a Corsair SSD USB drive.. this so that if something goes wrong, and the registry gets modified in some unintentional manner.. I can recover.
This is really really nice!
10-07-2017, 10:49 PM
Slight addendum:
Now.. with all this perspective.. I am seeing subtle signs that two things may cause "damage" to a working system that has followed the migrate path to Windows 7.
1. If you use the [Reset] button while looking at the [Video] panel in setup - all levels will automatically be set to (zero).. the same as the non-functional DirectX Video Proc Amp panel.
2. [Initialize] seems to trigger a dependency on DirectX information.. which may disassociate the video capture device from a working DirectX profile.
Basically MMC will work as long as you do not use a control that relies on information from DirectX.. the information DirectX reports back to MMC will put it into a non-functional mode.
That means essentially the [Setup] or [Initialize] panels must be writing to the registry and if the information makes no sense.. the reg settings get set to non-useful values.
You should be able to override these and manually set them using the slider controls, or modifying the registry.
A more sophisticated "fix" would be to "hook" the controls and intercept these problems.. [gray out] the features, or redirect them to custom versions.
More expediently.. a simple reg.bat file that reset things would probably be best.
Over thinking things is a problem I have.. so backing away from this problem to continue down the path of trying a repackage for a direct install on Win7 or Win10 would probably be more productive at this time.
10-07-2017, 11:08 PM
Aero themes are not compatible with ATI MMC and Windows 7 will automatically switch to a Basic theme and continue to load the program.
Wallpapers other than [solid] will "hide" the Full Desktop TV image. If you minimize the TV app it defaults to taking over the desktop background and displays a Live TV image. If you pick a desktop picture or image, this will cover it up. Changing the background to a plain solid color will reveal the Live TV image when the TV app is minimized.
10-08-2017, 07:41 PM
Sneak attack
Working on capturing a WinINSTALL LE repackage of the install on a clean Vista x86 install.
I couldn't [fix] the problem of the ATI TV Wonder USB2 drivers "failed to copy file" but I did figure out what it was trying to do when it failed.. and found a work around.
For some wacky reason, when the INF file is being processed, it can copy (some) WDM driver files to C:\Windows\Temp and fails to copy others.. a look at \Inf\setupapi.dev.log "suggests" a binary hash problem with the driver catalog.. at least that is what it claims.. so I think one of the new Vista security services was preventing the copy operation for some files, but allowing others.. weird.
So..
Before starting the cdrom setup program.. I copied all them to C:\Windows\Temp
D:\Install\TVW_USB2\WDM
to
C:\Windows\Temp
as far as the ATI setup program is concerned it thinks it copied them there, even though they are already there.. it certainly can't overwrite them.. because Vista is preventing it.. and the ATI install program continued merrily along.
Device is discovered and all the device drivers are successfully added to the Vista operating system.
Flakey or not.. the install succeeds and the MMC see the devices and proceeds to install.
10-08-2017, 07:56 PM
My primary concern is overlay in VirtualDub 1.9.x+ .
2nd concern is ATI MMC (for 15mbps MPEG-2 capture on dual/quad-core).
Where are you on that?
Hint: since we're talking WinVista/7/8/10, look at VirtualDub Filtermod Plus, which is a stable variant of 1.10.x.
https://github.com/eladkarako/VirtualDub-FilterMod-Plus
The x64 version may be useful for capturing in our endeavors.
Another hint: VirtualDub 1.5 -- and earlier, and 1.6, and Mod, but don't waste time on those -- have an overlay that acts different. It's softer/blurrier, but often succeeds where 1.8/9/10 fails. It's a god test to see if *something* works, in regards to overlay. As you know, minor successes can lead to later major successes.
I can get my PCI to act fine in MMC or Vdub 1.5, but not 1.9/10. Something broke when I installed new drivers, when downgrading the PCIe to PCI. The AIW USB acts identical. I'm going to reformat as WinXP later tonight, after the Yankees lose (hehe).
I'd be happy, for now, with overlay 1.9 Vdub + MMC on XP. For me, that's be a victory (although one that's NEVER been hard before). Trying to recreate this in Win7 would be great, as I could upgrade to SSDs! An enemy of audio (in video) work is noise, and removing spinning disks is a biggie.
Recreating in Win7x64 would be the impossible come true, and be a game-changer. Modern system hardware (motherboard/CPU/RAM/etc), modern-ish OS, legacy capture.
But it all starts with overlay and MMC.
10-09-2017, 12:18 AM
I think I'm still playing catch up to you.
I just got Vista reliably installing from cdrom, and upgrading to Win7 x86/32
I also just captured a Vista install of the MMC install to an .msi with WinINSTALL repackager
.. curious, the repackager indicated the ATI software was compiled with language support required "English (Canadian)" all the other binaries are English (United States).. not sure but that could have thrown a monkey wrench into certain installs. We tend to not install with additional language support. English is English, but there are slight variants.
I wanted to see if this captured .MSI installer could install "direct" to Win7 x32 .. then try Win10 x32
There is a "slight" extremely small chance the .MSI installer will work on x64 because even though DirectX deprecated certain interfaces.. ATI apparently wasn't playing by the rules.. they talked direct to the hardware.. even though the DirectX interfaces were removed.
I'm still working only with the ATI USB2 device.. and haven't unboxed the PCI/PCIe cards yet.
So my progress would appear frustratingly slow.
10-09-2017, 12:29 AM
ATI was Canadian. Although U.S. is always the primary market for tech, hence first on language support even when Canadian company, that was clearly an oversight on their part. Interesting.
Focus on the USB and PCI. PCIe will probably waste your time. The PCIe generation required a driver that would not be seen, at all, in Vista or 7. Only the AGP and PCI had success (in my tests), and USB (in yours). I still think the USB will be less compatible than PCI, but am following your posts with great interest.
Overlay and MMC is the holy grail here.
XP should be easy (but isn't on PCI/USB), Win7 x86 good target to shoot for (probably via Vista upgrading).
On another note, I don't really think Vista/7 Home vs Ultimate/Pro will do much differently. However, I don't know for cetain, so not willing to dissuade you from that thought avenue.
10-09-2017, 01:13 PM
Thanks for the audience
Exploring is a end goal in itself, but it gives me that incentive that keeps me coming back sooner than later.
I've already found the ATI software "works" completely on Win7 x86 due to your suggestions and encouragement. I really was not thinking that was possible after installing and seeing it fail to initialize video. Coming through the Upgrade path, I see its more a registry settings problem, and that DirectX simply changed between Vista and 7 and that made the software incorrectly start misconfiguring itself on initial install. If its installed "before" you Upgrade to 7 it keeps working as before.
I've also discovered the [solid] work around of copying the WDM drivers to C:\Windows\temp (before) attempting to install the drivers using the ATI Driver install package. Something is blocking the step where that package copies the drivers to C:\Windows\temp (before) it actually copies them into the driver store and initializes them in the registry. Doing that "pre-step" makes the ATI software installs ["stable"] on Vista.. and I suspect the same on 7.
It could be this is true (also) for PCI but I haven't tested that yet.
Overlay technology is the "Sticky" bit. DXVA is DirectX Video Acceleration. DirectX begain in 9 with it being totally in the software side of things, but as GPUs got more powerful, DXVA1 and DXVA2 pushed more and more of it into the GPU hardware driver side offloading the responsibility. So in later DirectX generations Overlay support began demanding your GPU support more and more Overlay functions. I am not sure if its even possible in 7 and 10 to revert that to software. -- all that to say, modern DirectX Overlay support is [highly] dependent on your Video card hardware drivers supporting overlay functions so that DirectX can use them. A cheap video card is unlikely to offer good (or any) Overlay support.
I also don't know how much ATI software simply offloads Overlay support to DirectX.
The ATI software is unpredictable in design.. some features they did not rely on DirectX, some they did.. at this point I think the only way to know is just (try) and see what happens.
Sad.. but it means it just takes a lot of work to find out.. if something will work.
I suspect the newer ATI MMC 9.x versions like 9.14 and above will have better support under 7 or 10.. but its only a guess.
I wanted to get the older 9.03 and 9.08 versions working first.. mostly (childishly) because I wanted to see the out of box experience work on Windows 7 and to see Video SOAP working on Windows 7 x86 (and it does work.. yeh!)
I think I should stop for a moment and test VirtualDub Overlay support on Vista and 7 just to "know" and will probably do that this evening.
10-09-2017, 07:41 PM
English (Canadian) = French Canadian keyboard
Canadian languages settings
Geez..
en English
en-us English (United States)
en-gb English (United Kingdom)
en-au English (Australia)
en-ca English (Canada)
en-nz English (New Zealand)
en-ie English (Ireland)
en-za English (South Africa)
en-jm English (Jamaica)
en English (Caribbean)
en-bz English (Belize)
en-tt English (Trinidad)
10-09-2017, 08:32 PM
Tested Vista with ATI MMC 9.08 installed, then installed the VirtualDub FilterMod from the link you provided.
I had to download the VC runtime from microsoft for VS2008 x86 before VDub would startup.
After that, it seems to work flawlessly except it doesn't capture audio.. which is weird because ATI MMC does capture audio... and plays it while viewing.
The Overlay function stays on during capture, it does not disable when capture begins.
I'd post a silly video of the interface I captured with my cell phone.. but it sort of felt childish posting a shaky cam video.
The video captures through VirtualDub with no frame loss (zero).
It is remarkably stable on Vista x86
Moving on to try it on Win7 x86
I have them backed up on a thumbdrive so restoring to working conditions is a Macrium restore that takes about 4 minutes.
10-09-2017, 08:58 PM
Tested Win7 with ATI MMC 9.08 installed, then installed the VirtualDub FilterMod from the link you provided.
Worked flawlessly (and) it captured audio, but did not play the audio during capture.
On playback in Windows Media Player the audio was there.. so I don't know if Vista was a fluke, or I toggled something I should not.. but it works perfectly with the Overlay mode under Win7 x86
If possible.. it even seems even "more" stable under Win7 x86.. the picture seems "more" stable in a way crisper than I thought it did under Vista.. and I thought the Vista picture was really good.
10-09-2017, 10:23 PM
Pretend I know nothing.
Give me the steps to recreate installing the ATI AIW USB in Win7 x86.
Right now, it seems to be:
- install WinVista
- copy some ATI CD files to the temp directory
- install ATI drivers from CD, install MMC from CD
- upgrade Vista to Win7
And done?
I want to replicate what you've done. Let's go ahead and do the USB first, since I have one.
10-09-2017, 11:13 PM
- install WinVista
And done?
Only missing (one) step.. which you would run into anyway.
Installed with Vista x86 SP0 (no service pack) then did as you said (after) ATI MMC is installed and working.. need to do that TV tuner initialize step while still in Vista, then apply Vista SP1 "before" Upgrading to Win7. -- it would have stopped you and said you had to install Vista SP1 anyway.
The big take aways (a) copy WDM drivers to c:\windows\temp "first" before using the normal driver setup routine (b) be sure to setup the TV Tuner while in Vista.. I "think" Win7 lost some DirectX tools that let it properly default setup the TV Tuner.. if you try it after Upgrading.. it probably won't work.. or will be flakey.
1. Copy the (cdrom) D:\Install\TV_USB2\WDM contents into C:\Windows\Temp
2. Then methodically went top to bottom through the cdrom through File Explorer to right click - Compatibility - XP SP2 on "every" application file, I sorted the files using the file explorer file type and all the executable application files floated to the top
3. Then ran atisetup.exe from the cdrom using Run As Administrator
4. finally while I could just do a default install, I got around to untagging the unnecessary stuff.. let it install the TV_USB2 drivers.. it prompts for you to plug it in.. detects it and flys right through without a single error
I do plan to make the steps much more detailed.. but I "think" I can get most of this automated with a cmd.bat file to perform the install without doing everything manually.
Right now I'm struggling with a WinX 1607 x86 install to try the similar steps on Win 10 (I think the only diff will be importing "sane" regsitry settings from Vista into the registry to get it working).
Eek! I forgot I did some "sane" stuff in Vista too.. disabled UAC for example.. I made copious notes.. coming soon.
Let me get this Win10 trial out of the way first.
10-09-2017, 11:21 PM
"untagging the unnecessary stuff."
Yes, I think that's important -- only install what's needed. I do that.
For example, for MMC, only TV. Not DVD, Eazylook, guide, etc. I don't even remember what some of that stuff, just that it's useless and not to be installed. Waste of time.
So when we discuss installing stuff, let's now overlook the cherry-picking.
Win10 is a horrible OS for everything aside from tablets. The main reason I still use Windows is for video. I use Linux and Mac quite a bit, too. I would expect 10 to fail miserably, and is just wasting your time.
10-09-2017, 11:32 PM
Finally.. got Win10 1607 installed
Every driver is showing up working and compatible.. finally
Taking a before snapshot backup of it now.
Its getting late.. but I should be able to at least see if the drivers install with the copy to C:\windows\temp first trick.
I have a long meeting starting early tomorrow so I will have to stop there tonight.
10-09-2017, 11:59 PM
Mixed results
Pre-copying the WDM driver files "did" let the driver install package install the drivers.
Windows 10 acknowledges seeing them.
But three of the critical drivers are not "fully" loaded, they have little yellow trouble cones next to them in the device tree and say "Object not found" "Device requires further installation"
I've seen something similar before.. it usually means a missing CLASSID in the registry for a subsystem that Microsoft has decided to rename, deprecate or remove. -- in short a "dependency"
Specifically the drivers that didn't fully load are:
ATI TV Wonder USB2.0 Video & Audio
ATI TV Wonder USB2.0 TV Tuner
ATI TV Wonder USB2.0 AV Crossbar
Those usually plug in with ksproxy.. or rather I should say.. usually ksproxy "probes" these user space drivers for interfaces for information to construct and activate the video proc amp panel among others. They started redesigning or constricting them in Windows 7.. I don't know what they did in Windows 8.. by now it looks like they just removed them.
But I have not installed the ATI MMC software yet.. got to go get some sleep.
The ATI MMC software continued to work even though the video proc amp panel stopped populating in Windows 7.
I did try to fire up VirtualDub and it couldn't find a video source for the ATI USB2.. that tells me the ksproxy isn't working enough to let it use the video driver.
Its a lot of information really fast.. so close
I don't know whether to be depressed, or jubilant in just knowing the status on Win 10.
Only throwing this out there.. but DirectX12 could have renamed the CLASSID for these "types" of driver.. maybe modifying the INF file or decorating the registry directly with the DirectX12 for video capture device CLASS would make them work.. i don't know.. that's a wild idea.. going back to document the Vista to Win7 path tomorrow night.
10-10-2017, 12:06 AM
Force-installing the drivers isn't hard, though it may still be rejected. The easy way is to look at the hardware ID.
- If you don't see the name of the device, you're fine.
- If the device name shows with a yellow (!), then you're usually screwed. It took it, but will not work.
^ At least that's been my experience.
Overlay has (at least?) two methods/modes. I mentioned this earlier.
- With my PCI card, 2nd system with XP problem, using VirtualDub 1.5, overlay works, but is soft. The ATI MMC is crisp. No 1.9 overlay at all.
- My main capture system has both crisp overlay in 1.9 and MMC. AGP Asrock dual-core build.
10-10-2017, 10:16 AM
Huh.. annother idea
SHA1 vs SHA2 driver certs
The signing costs for Windows 10 hardware drivers have been going up and up.. its now like over $1000 per year just to get a signing cert for drivers.. and Microsoft has separate (validate) and (verify) steps when loading drivers.. example: is it SHA1 or SHA2, is it a self signed cert or a private or public cert... policies prevent self signed loadable unless your in test mode and unverified mode. but that doesn't mean it doesn't have to be signed.. even if badly signed it has to be signed.
Not to mention the signing certs used to sign the ATI drivers expired a really long time ago.. so while signed.. by the new enforcement standard, they would validate but fail because the certs were expired. These new enforcement standards are being ramped up since Windows X started using 4 digit version numbers.. I miss the Windows 2 digit version numbers.
I forgot how [bad] Microsoft has made it for any programmer to get software or hardware to run on Windows 10.. its really become super bad in the last year. the AU and Cartoon Updates have made it almost un-runnable.
You can try the F8 disable verify, validate, behavior if fails either.. and loadable test signing steps.
I use to run usb snoopy on Windows 10.. and it was really really hard.
It could be simply.. very simply be that Windows 10 is failing one of these steps and "preventing" a verified and validated driver from being "loadable".
Its a real circus these days.
I really need to remember to try all this when I get home.
10-11-2017, 09:58 AM
Last night performed [both] an install and an upgrade from Win7 to win10.
Both had same result, the software appears to upgrade in a functional state but in both cases the hardware device drivers seem to say they are missing some operating system component that is inaccessible or has gone away in win10.
But otherwise the software appears functional, ATI launcher, configurator, TV App, Player App, Library App all start without error.. except for not being able to find the TV Tuner.
The Cypress chip bus driver for the ATI device loads.. its the logical components that are directly connected to DirectX that start to load and then say something is missing.
So Win95, 98, ME, NT, 2000, XP, Vista, 7 (all x86, 32 bit versions.. none of the x64, 64 bit versions have been attempted) are known to work with these drivers.. if wacky to install
On win10 ATI software is known to install, but not complete the connection to DirectX
I do not know about Win8, 8.1
