10-13-2018, 10:17 PM
facp facp is offline
https://youtu.be/EHYRfukHToc
This looks like an epic documentary with an incredible job at film restoration. I'll be very interested in seeing a "behind the scenes" featurette for this. Wow!
10-14-2018, 04:18 AM
It still looks colorized, but most impressive nevertheless.
10-14-2018, 04:45 AM
Eric-Jan Eric-Jan is offline
That's just what's it all about ! if you can do it better ..... ?
10-14-2018, 11:32 AM
JPMedia JPMedia is offline
I'm curious about the workflow on a restoration project like this. First do they scan every frame, use a piece of software like Photoshop to remove all dust, dirt, and other residual artifacts, create a digital video file from the corrected frames, then color correct, etc?
Restoration of VCD naripeddi Restore, Filter, Improve Quality 16 08-20-2018 02:38 AM
An Example of VHS Audio Restoration (JBB) lordsmurf General Discussion 6 08-24-2014 11:43 AM
Cartoon restoration project - film grain noise removal? via Email or PM Restore, Filter, Improve Quality 1 07-26-2014 11:39 AM
Advice on scanners for slides, negative film and 8mm film movies? lordsmurf Photo Processing, Scanning & Printing 3 12-29-2009 11:48 AM
