06-30-2019, 07:02 AM
Can somebody recommend a proper remote for my ES-15s?
I know it is the remote that failed because my Panny TV remote will run it, but it seems I can only get to the Noise Reduction selection but cannot get to the black levels screen.
Thank you,
BTC
06-30-2019, 10:42 AM
Feedbucket Feedbucket is offline
It's on ebay.
I control all my gear using a Harmony 350 (also found cheap on ebay) so I don't need to mess with multiple remotes and multiple batteries (ugh). It's programmable and supports the ES15 fine.
The following users thank Feedbucket for this useful post: BarryTheCrab (06-30-2019)
07-02-2019, 05:38 AM
These are the models:
- Panasonic EUR7659Y20
- Panasonic N2QAKB000055
It's usually easier + cheaper to look them up by model number. The remotes sold by recorder model are usually more expensive, in worse shape, and from China and Hong Kong. So beware of that problem.
ES10 and ES15 remotes are interchangeable.
But even some other model remotes work, like the one from my E80H.
The following users thank lordsmurf for this useful post: BarryTheCrab (07-02-2019)
es-15, panasonic, remote
DMR-ES15 passthrough functions? homefire Capture, Record, Transfer 9 05-14-2019 12:59 PM
For Sale: Panasonic DMR-ES15 DVD recorder TBC w/remote [SOLD] ridzoman Marketplace 0 04-16-2019 05:28 PM
Question on Panasonic DMR-ES15 (EU-PAL) U-max Restore, Filter, Improve Quality 4 08-19-2018 05:58 PM
JVC HR-S9911U and Panasonic DMR-ES15 remote for sale [SOLD] history1 Marketplace 5 01-04-2015 08:35 AM
