08-18-2019, 04:32 AM
dima dima is offline
1. Have you ever seen VHS cassettes with this well-known "VHS" stamp and under it the inscription: "PAL SECAM" ?
From what I know, in some of the countries there was a situation of recording the signal in PAL, but converting the material for television to SECAM (television broadcast in such a system).
2. I don't know how the situation was in the case of VHS recordings. Do you know ?
3. Even if it was so that VHS cassettes were also recorded in PAL, then converted to SECAM and distributed in this way, capturing in PAL would probably provide the best color quality for such material than if it were captured in SECAM ? Would have to check it yourself in practice ?
[The VHS cassettes, which I have from the nineties and the twenty-first century, the stickers that are stuck on the cassettes have a known stamp: VHS, and under it the inscription: "PAL SECAM". Only "VHS" is engraved on the cassettes (plastic).]
4. What is the difference between D and K systems: Is it for PAL or is it for SECAM ?
As far as I know, D and K systems were used here(Poland) for television (whether for SECAM or PAL; for television: SECAM was used until 1993/1994 and later PAL). The differences I know [for TV] are apparently: D used in the VHF band, and K in the UHF band (for PAL; I don't know for SECAM differences).
5. Which PAL (or SECAM) system should I use to capture the signal from a VHS cassette [Poland] ?
Theoretically, there should be some connection with these systems between television and VHS recordings (especially private ones). Perhaps it also depended on the recording camera which one had (the equipment) - from which country and which VHS tape was used.
08-20-2019, 11:54 AM
VCRs in Eastern Europe recorded SECAM broadcasts in MESCAM format, which most all modern PAL VHS decks can playback without any issue.
https://en.wikipedia.org/wiki/SECAM#...home_recording)
The only exception are tapes from France that were recorded using a French market VHS VCR (SECAM-L). Those tapes will not play in color on the more common MESECAM decks, but the tapes are rarely encountered outside of France.
Best way to capture home recorded TV shows? Sonic76 Capture, Record, Transfer 5 03-06-2017 04:17 AM
Honestech video capture not detected, recorded in LP? naturally Capture, Record, Transfer 3 12-06-2015 07:58 AM
Capture 8mm cassettes workflow advice tomr Project Planning, Workflows 14 01-07-2013 11:56 PM
Problem with SECAM VHS playback / tape capture monks19 Capture, Record, Transfer 4 03-04-2012 10:04 PM
