Camera, tripod, light source and mic for shooting videos?
This is a tiny portion of a conversation that start in email.
Because it may eventually involve a DSLR as an option, I'm adding it into the photo forums... Quote:
Camera: Do you want HD (widescreen) or SD? Does it matter? I'd probably opt for HD. - What sort of budget? I can recommend everything from consumer budget rigs to something that needs its own lenses. In some cases, even a good DSLR may work, but there are limitation. Lighting: This is one of my weaker areas, as video requires sustained lighting. I'm primarily a still photographer when it comes to shooting. But I can find good information easily, from colleagues who do the shooting. Microphone: Another area where I'm weak, but actually learning. My new Nikon dSLR camera comes with 720p HD video, and I need a good mic myself. Learning all about condensers, etc. - Do you plan to use this only inside? - Does your mic purchase need to work for more "universal" settings? - Do you want something that can be clipped onto a shirt, held in a hard, or simply mounted on the camera? Lets get you set up with something. :cool: |
