Go Back    Forum > Digital Photography > Photo Processing, Scanning & Printing
01-23-2011, 05:14 PM
need a bit of advise: how to remove redness from pic:
the common thing on the internet is red-eye removal
but does this need a different technique?
any help you can give will be appreciated.
cheers
Use Photoshop.
Open the image in Photoshop.
For this quick "proof of concept" fix-it, I'm using Photoshop CS3 Extended.
Go to
Image > Adjustments > Levels
Click the Auto button
It will readjust a lot of the colors quite decently.
Feel free to adjust levels manually, or further tweak past the auto settings.
OK
Now let's take care of that still-problematic harsh red color saturation
Goto
Image > Adjustments > Hue/Saturation
and it brings up a new settings window.
Edit: Reds (from dropdown box in the new window)
  • reduce saturation about -28
Edit: Magenta
  • reduce saturation about -17
  • reduce lightness about -53
Feel free to "play around" with other colors, or alter these settings to something you feel may look a bit better. Again, this is a quick proof-of-concept example, not a fully-tweaked perfectionist example.
OK
And you'll get this:
It's clearly not photo-perfect, with some remaining color issues, but it's still much better than what it started as.
Hope that helps.
The following users thank admin for this useful post: manthing (01-23-2011)
01-23-2011, 05:44 PM
manthing manthing is offline
hey thanks man.
that sorts out a lot of the problems.
The following users thank manthing for this useful post: lordsmurf (01-24-2011)
DV color space harmful to analog color quality? Verify? DeXeSs Capture, Record, Transfer 6 06-27-2010 01:48 AM
Remove DMR lock & convert cnickle1 Encode, Convert for discs 5 03-22-2009 01:11 PM
How can i remove black bar from side of mpg?? Konfusion Restore, Filter, Improve Quality 12 11-27-2007 05:04 AM
Satellite problem: wavy lines in picture Skuff Videography: Cameras, TVs and Players 11 08-09-2006 12:43 PM
Remove text from pic, but leave background? manthing Photo Processing, Scanning & Printing 2 03-27-2006 12:47 AM
