12-20-2012, 11:10 PM
naripeddi naripeddi is offline
I normally scan and store important documents & printed photos.
I have a lot of photo negatives that I would like to scan.
I currently have a HP all-in-one unit, but I see people suggesting a stand-alone flatbed negative scanner for best photo scanning results.
Please suggest a current good model. I don't want professional-grade due to high costs.
regards
01-02-2013, 01:07 AM
JMP's Avatar
JMP JMP is offline
Former Site Staff | Computers
"...I see people suggesting a stand-alone flatbed negative scanner for best photo scanning results."
Yes, a flatbed negative scanner will be the best choice.
"I don't want professional-grade due to high costs."
What is your budget for something like this.
Thanks,
-JMP
01-02-2013, 02:04 AM
Around $300.
01-02-2013, 09:09 AM
juhok juhok is offline
Flatbed is quite bad for film scanning and usually even worse for negative film which is sometimes tricky for even the high end film scanners. Epson V700 which is among the best flatbed scanners for film is over your budget and quality is not so good even then, and scanning is slow and cumbersome.
In a budget I'd try to find second hand older dedicated film scanner, like Nikon Coolscan or Minolta.
For new ones, Reflecta and it's rebrands should be better than flatbed - http://www.scandig.com/filmscanner/reflecta/index.html (there are a lot of good technical reviews on that site about different scanners).
01-08-2013, 12:19 AM
JMP's Avatar
JMP JMP is offline
Both of these Plustek linked here are good for scanning negatives. There is one $400 which is a better scanner, so if you are able to budget $100 more, it is well worth it. You can always resell it later and get some if not all of your money back for it.
The alternative is an Epson V600 or better, which is good at slide scanning, but not as good at negative scanning. In this situation, I would recommend the Plustek. If you are in a situation that needs both, that makes for a hard choice.
http://www.bhphotovideo.com/c/produc...3167/KBID/4166
-JMP
01-08-2013, 12:56 AM
Thanks guys.
Regards
Scanning paper with sheet fed scanner, JPG vs PDF Sossity Photo Processing, Scanning & Printing 3 11-10-2012 12:06 PM
Flatbed scanner vs. Neat Receipts (sheet fed scanner) vs. copy paste? Sossity Photo Processing, Scanning & Printing 4 10-23-2012 09:53 AM
LCD Monitor Suggestion for Editing VideoTechMan Computers 4 04-01-2012 09:53 AM
Sheet scanner vs Flatbed scanner - Going paperless in my home (or nearly paperless) Sossity Digital Devices 1 10-03-2011 10:39 AM
Buying DVD cases - archived negative reviews admin Blank Media 0 11-05-2009 04:53 PM
