09-23-2019, 10:47 AM
bar72 bar72 is offline
Hi All,
So I picked up a Panasonic DMR-EZ49V in a junk shop the other day. Can't believe that it records DVD-R with LPCM Audio in XP Mode.
So, I transfer a lot of old Music VHS, usually the type that never saw DVD-Video and always want lossless Audio.
VHS plays back Hi-Fi Audio perfect? Can't believe it
AV3 In, in the picture, is not significant, I'm on about direct VHS > DVD-R copy using only the DMR-EZ49V
Is this a worthwhile machine, for direct transfer, meaning I drop the Panasonic DMR-ES10 that I have for a intermediate TBC or should I hang onto it and keep capturing to my Windows Se7en Desktop PC?
Lossless LPCM is more important that video quality to me, by the way ;
thanks in advance for any info on this combo device.
09-23-2019, 03:01 PM
You might want to read up on the EZ "series" around the web, on some other sites they mention finalizing discs and editing as being a major pain, if not flawed.
But you have a special need for LCPM.. so perhaps it could be an exception in this case.
The following users thank jwillis84 for this useful post: bar72 (09-24-2019)
09-23-2019, 04:42 PM
Depends what you're comparing it to. This deck is essentially a VHS player with a DVD-Recorder permanently attached (likely via composite video), with the positives and negatives that entails. It seems to lack S-Video output but does have HDMI out instead. If you mean using a DMR-ES10 with this one it won't stabilize the signal any since the video already has been digitized (and output back to analog on the composite and RGB outputs) in the VCR combo. Since it has HDMI output you may be able to capture directly from that to a computer too.
You would have to test really to see how well it works compared to a different setup.
The following users thank hodgey for this useful post: bar72 (09-24-2019)
09-23-2019, 04:48 PM
This item does not have, nor double as, a timebase corrector.
It's just a cheap low-end combo DVD recorder with a really crappy VCR inside. You'll have all sorts of timing errors, including wiggly image and chroma noise.
BTW, LPCM may not be uncompressed from start to finish, meaning an intermediary step compressed it first, before extracting back out to LPCM for storage. I've seen this happen on other devices.
If uncompressed audio matters most, go the capture card route, using a quality audio card like Turtle Beach Santa Cruz.
The following users thank lordsmurf for this useful post: bar72 (09-24-2019)
09-24-2019, 03:23 AM
thanks to all for clearing things up for me. Only paid 20GPB so no great loss ;. Back to the old capture card then for true LPCM. Thanks for the info on that Lordsmurf, didn't release that intermediate compression occurs on some players.
By the By, can Chroma Noise be fixed using avisynth scripts, post-transfer?
capture, dmr-ez49v, panasonic, transfer
What is a TBC? Time Base Correction for Videotapes lordsmurf Restore, Filter, Improve Quality 169 09-10-2021 12:17 PM
Wanted: Time Base Corrector (TBC) demitri Marketplace 0 07-08-2018 12:33 AM
Are video mixers a good option for Time base correction? gazmono Capture, Record, Transfer 0 08-15-2016 07:19 AM
Gallery of Time Base Correctors Giana Restore, Filter, Improve Quality 3 04-07-2012 06:02 AM
Time base correction - Which unit to buy? johnny aussie Restore, Filter, Improve Quality 1 09-18-2011 06:10 AM
