01-29-2020, 03:33 AM
meeshu meeshu is offline
I have a Mitsubishi VCR that used to work fine, but recently cassettes now fail to load, and prior to that, cassettes failed to eject.
I've had a look inside the unit, and found the cassette "basket" or "cage" stuck about halfway along the range of movement that the cage makes when loading and ejecting cassettes. The cage is slightly askew. I tried straightening it and moving it by hand carefully, but the cage will not move.
Powered the VCR off and then back on, and tried the eject button on the VCR. There is a whirring sound like an electric motor running, but the cage will not budge.
The VCR will probably require professional attention.
Anyone else have have a similar issue? And if the issue was resolved, how?
01-30-2020, 05:06 AM
Something may be stuck.
Or the motor may be failing or failed.
Without the unit in-person, it can be difficult to troubleshoot. However, at minimum, we need images (and attached to the thread/post).
01-30-2020, 02:53 PM
josem84 josem84 is offline
Huge mistake there... never force the mechanism. Unplug the VCR and complete the loading cycle by hand to see if there's any broken part. It could be a belt too... We're just speculating as we don't have anything to look at.
01-31-2020, 04:19 AM
Thanks for the comments.
I'll try to take some photos of the cage and surrounding parts tomorrow.
The cage was not forced hard by myself. I only applied gentle force to see if it moved, so I doubt my attempts would have caused any (further) damage.
01-31-2020, 06:07 PM
Here are a few photos of the VCR cassette "cage". Top, left, and right views of the cage.
I believe the VCR was attempting to load a cassette when it "jammed".
01-31-2020, 11:33 PM
You need to unscrew the tape cage and reset it, Look for broken gears on the sides.
Samsung SV-5000W world vcr tape won't eject? waloshin Video Hardware Repair 1 09-30-2018 04:32 PM
JVC HR-S6900U turns off after tape insert or eject? Y4BB Video Hardware Repair 6 08-14-2018 10:06 AM
8mm cassettes won't load? (Video8/Hi8 VCR) JVRaines Video Hardware Repair 6 05-28-2017 09:51 AM
Panasonic NV-FS200 eject problem? frederick Video Hardware Repair 3 03-14-2015 04:12 PM
NV-HS1000 won't eject tapes Medusaman Video Hardware Repair 3 03-12-2013 03:10 AM
