^ lol, what do you mean you just found it? On the ground?
Those USB IDs indicate it's the most common EasyCAP (EasyCRAP) out there; the EasyCap DC60 (Syntek STK1160 chip). I compared its quality using test patterns
here.
Note: I requested a sample of the now-working capture, because I'm considering buying this VCR model locally and I'd like to get a rough idea of how my tapes may look played through it. The OP was kind enough to provide a 7-second MP4.
VCR
Sharp VC-H960 = VC-H960U is a (North) American machine, NTSC format. There is no PAL variant with this part # scheme.
The sample MP4's MediaInfo
General
Complete name : C:\Users\Brad\Downloads\clip.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/mp41)
File size : 8.95 MiB
Duration : 7 s 340 ms
Overall bit rate mode : Variable
Overall bit rate : 10.2 Mb/s
Encoded date : UTC 2020-04-09 15:05:29
Tagged date : UTC 2020-04-09 15:05:32
©TIM : 00:00:00:00
©TSC : 50
©TSZ : 1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 9 848 kb/s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 50.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.641
Stream size : 8.62 MiB (96%)
Language : English
Encoded date : UTC 2020-04-09 15:05:30
Tagged date : UTC 2020-04-09 15:05:30
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Source duration : 7 s 381 ms
Bit rate mode : Variable
Bit rate : 317 kb/s
Maximum bit rate : 349 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 284 KiB (3%)
Source stream size : 286 KiB (3%)
Language : English
The sample MP4
It's 640x
480 @
50fps, encoded in progressive mode. This is a mix of standards, and should never happen.
You should capture
720x480 @
29.97fps, then
if desired* deinterlace to
59.94fps (double-frame-rate deinterlacing, aka "bobbing"). The MP4 sample is missing half the temporal information; the underlying frame rate is actually 30fps, with duplicates added to bring it up to 50fps.
I've attached a sample where I used the filter
TDecimate with option
Display = True and then re-compressed with x264. The Display option shows where the duplicate frames were detected and removed. They have metrics ~
0.3. Metrics for duplicates are typically <
0.5 depending on noise level of source, in my experience.
Short Avisynth script:
# Load video clip, with audio
V = FFVideoSource("clip.mp4")
A = FFAudioSource("clip.mp4")
AudioDub(V,A)
# Remove duplicate frames (remove 2 of 5; keep 3 of every 5)
TDecimate(cycleR=2,cycle=5,display=true)
* Depending on your chosen
delivery format,
playback devices, etc. it may make more sense to encode in
Interlaced mode, retaining
[a compressed version of] the original fields. This does not apply if you will only ever be sharing these using web-based players like YouTube, Facebook, Instagram, etc. In that case, definitely deinterlace and encode Progressive.
The saturation of this clip is also extremely low. Meaning: it's almost black-and-white. Maybe that's just how the camcorder recorded in this low-light situation.
I would appreciate it if you can attach a 720x480 @ 29.97fps clip of a TV recording or movie using this VCR (30 seconds or less, if in MP4 format).
Let me again say thank you for sticking around. I was really worried you'd be a
2-hit wonder.
- "Here's my problem. Help!"
- "Oh never mind, [SOLVED.]" Without explanation of specifically how, for others who might have the same problem in the future. This is my biggest pet peeve about Internet forums.
