Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
06-27-2007, 07:04 PM
manthing manthing is offline
i did a background motion menu recently
a 4 min clip
dvdlab pro 2 took about an hour to render the motion menu!
so my quesiotn is how long does Ulead DVD Workshop 2 take to do a similar length motion menu?
06-28-2007, 01:39 AM
DVD Lab was likely doing things it should not, as usual. I'm not a fan of that software. It has a really subpar encoder, whereas DVDWS2 uses the high-grade MainConcept 1.4 engine.
On my computer, a 4-minute menu might take 15-30 minutes of encoding time, for a total of 30-45 minutes of authoring time to create the folder set. Burning, which I do in a separate application (ImgBurn or RecordNow Max) takes abother 15 minutes on a 4x burn.
06-28-2007, 04:19 AM
cp32 cp32 is offline
I agree with LS. Switch to Ulead . You ll never look back
06-28-2007, 07:28 AM
padre2 padre2 is offline
On my computer, using TDA v3.0, it takes about 30 minutes to encode a 4 minute motion menu.
Was there anything unusual about the 4 min clip? High bit rate?
06-28-2007, 08:05 AM
yeah maybe bitrate was a tad high. i'll test out DVDWS2 over the weekend and see for myself. thanks gang.
How to add background music in Ulead DVD Workshop 2 Superstar Author, Make Menus, Slideshows, Burn 1 07-28-2009 07:28 PM
Ulead DVD Workshop 2 Menu Problem bigk181 Author, Make Menus, Slideshows, Burn 1 12-15-2008 09:13 AM
Question about menu buttons using DVD workshop 2 MBates05 Author, Make Menus, Slideshows, Burn 2 11-12-2005 10:18 AM
Ulead Dvd Workshop 2 help? emokid Author, Make Menus, Slideshows, Burn 12 07-11-2005 11:52 PM
? about wavy motion on video menu in dvd workshop MBates05 Author, Make Menus, Slideshows, Burn 3 06-15-2005 05:19 PM
