Does this happen with all tapes or only some?
Has the machine worked OK recently?
There are a number of reasons a tape is spit out after a few seconds. They mostly result from the VCR's controller detecting an unexpected condition, such as not fully loading, loose tape, incorrect sensor response, misaligned switch, some debris in side the machine, etc. Some units will show an error code on the display
FWIW: Finding the service manual might help diagnose and repair the unit.
It can be found/bought bought on line, but finding parts can be problematic at best, and whether or notit is worth repairing is a separate question.
