10-27-2020, 04:31 PM
halopower halopower is offline
Hello,
I have a video cassette which is unfortunately problematic. Namely, there is a problem with rewinding - I actually failed to do it. I tried two VCRs and both have the same problem - the devices do not have the strength to rewind it. I will add that I copied several hundred carriers and so far I have not come across such a resistant cassette.
I am asking for any advice, tips on how to solve this problem.
10-27-2020, 04:34 PM
Are you sure the tape hasn't degraded, sticking to itself?
10-27-2020, 04:45 PM
is it possible? How to check it, how to fix it? Have you had this type of problem in the past?
10-27-2020, 04:51 PM
You need to open the tape clamshell, remove the spools, see if you can manually wind. If not, then you know that's the issue. If the spool win fine, then you know the clamshell was bad, and needed to be opened anyway.
The following users thank lordsmurf for this useful post: halopower (10-30-2020)
hard to rewind, video cassette problem
Kodak High Standard color video VHS cassette good? hereandelsewhere Blank Media 6 01-05-2020 11:36 PM
Fast forward and rewind VHS before capturing? Padawan Capture, Record, Transfer 12 10-08-2018 11:11 AM
Problem capturing NTSC format video cassette dudu2683 Capture, Record, Transfer 5 09-29-2013 11:17 PM
SLV-R1000 rewind issue volksjager Capture, Record, Transfer 5 07-01-2012 01:25 AM
Sony VO-5600 U-Matic Video Cassette Recorder [SOLD] stoogedog Marketplace 1 05-25-2008 08:15 AM
