10-30-2007, 07:10 AM
shadowkaos shadowkaos is offline
Send a message via MSN to shadowkaos Send a message via Yahoo to shadowkaos
I've been recording the Raccoons and by accident I left the Recorder on XP mode for a couple of episodes. I'm putting 5 to a disc with Ulead DVD Workshop 2 and am having trouble fitting them on a disc. What is the best way to encode them down to an SP file size?
10-30-2007, 08:11 AM
manthing manthing is offline
something like tmpgenc xpress or some other converter.
or possibly encode it to the bloated size, then use dvd shrink to fit onto a dvd.
for cartoons, either should be okay.
but then again, i'm not expert enough to give a definitive answer.
other than to say, i've used both methods and i have no complains!
10-30-2007, 09:29 AM
I suggest using MainConcept 1.4 or higher for the best quality conversion. It's the best one out there right now, and it's what I use when I do something like this.
DVD Shrink will lose a lot of quality, especially on homemade discs. Stick to true encoders, and use the better ones.
Is SP MODE the Best DVD Recorder Mode? (NO!) lordsmurf Capture, Record, Transfer 4 04-14-2013 10:01 PM
Dual layer DVDs - SP mode is 4 hours? admin Blank Media 0 05-20-2009 05:17 PM
MPEG encoding and DVD burning questions Reading Bug Encode, Convert for discs 3 05-13-2009 07:18 PM
Opinion of recording in Widescreen mode? padre2 Capture, Record, Transfer 1 10-18-2005 10:43 AM
Panasonic 4-hour mode illustrated lordsmurf Capture, Record, Transfer 2 09-12-2005 06:47 AM
