01-18-2021, 12:20 PM
ibpete ibpete is offline
First off let me say this forum has been a Godsend. I've learned so much and have managed to do my due diligence and not ask repetitive questions.
Now I have something I haven't seen before.
I'm only getting Virtual Dub video display (and capture) when i pause my VCR. As soon as I hit play video goes dark. I'm using VC500 as capture device.
I know it's likely something dumb but I've double checked everything.
This is happening on two different PCs, one of which I have successfully used before.
Any ideas on what I might check?
TIA
Mike
01-18-2021, 01:21 PM
bookemdano bookemdano is offline
What VCR are you using? Have you tried connecting the VCR to a TV to make sure the output is working properly there? Do you have another VCR (or camcorder, or DVD player, etc.) you can try connecting up to the VC500 to see if those show the same symptom?
01-19-2021, 02:38 PM
VCR working fine.
Mike
Well, I guess it was something dumb. I was fitting up an XP PC for video capture and evidently had an incomplete configuration. Ran the VC500 set up again and now it's working. I think the big culprit was I hadn't installed DirectX.
As a side note--I had been capturing with a Win10 Laptop which was giving me the same display. I've got the XP machine working now but now the laptop is broken. Nothing changed since yesterday (unless MS pushed some crap on me) and now VirtualDub just hangs up. I can't even kill it, have to reboot.
This isn't a question yet just an observation. I was only playing with the laptop to troubleshoot my VC500 and cabling.
Best regards,
Mike
01-19-2021, 11:39 PM
"dark" (luma being damaged) or total blackout?
If luma, false anti-copy is likely -- lack of TBC. What is your workflow?
A reason why Win10 is a bad capture OS.
This is actually a reason to NOT allow DirectX in VirtualDub. Disable it in preferences.
Options > Prefs > Display > Disable DirectX
This is disabled on all my systems, because it's either unstable or messes with video values in preview.
JVC HR-DVS3U No picture in play, but image in pause/FF? Jfeat Video Hardware Repair 6 08-15-2023 04:41 PM
VirtualDub not capturing? WarbirdVideos Capture, Record, Transfer 6 12-27-2019 11:08 PM
Useful filters in VirtualDub when capturing? icnkay Restore, Filter, Improve Quality 1 02-08-2018 08:52 PM
After capturing VHS with VirtualDub, how to proceed? Superopa Capture, Record, Transfer 12 01-13-2017 06:43 AM
No audio when capturing with VirtualDub TylerDurden389 Capture, Record, Transfer 17 04-15-2014 05:27 PM
