02-04-2008, 11:37 AM
cnickle1 cnickle1 is offline
I'm trying to rip a movie from a disc created by a dvd recorder with dvd decryptor in IFO mode. It rips fine (the resulting file is about 4 gig), but all of my different authoring software only recognize the first 30 seconds of the movie when I try to import it. For that matter, media player will only play the first 30 seconds. What am I doing wrong? My end goal is just to get a better looking menu for this movie.
02-04-2008, 06:40 PM
cp32 cp32 is offline
Follow this guide.
http://www.digitalfaq.com/dvdguides/...corderedit.htm
My rca records in some weird ways... I ll have what looks like 2 large 2 gig files. When it is only 1 movie. go figure.
You could import the dvd through TDA save as mpeg.
02-05-2008, 12:39 AM
Thanks - but that didn't help. The different programs that I have to edit and play the ripped file(s) seem to only recognize the first cell of each chapter. Help!
02-05-2008, 05:21 AM
Try mpeg vcr > Import vob > convert the file type to mpeg2 program stream.
Your authoring program should recognize it then. Unless the file is corrupt?
02-05-2008, 06:21 AM
JonathanEntertainment's Avatar
JonathanEntertainment JonathanEntertainment is offline
I have used Nero Recode for recompiling DVDs and it works fine for me since that Alcohol 120 doesnt work for me sometimes and cause bad burns
Arrow Chat now $45 - click Here
02-05-2008, 06:35 AM
I know what the error is. The MPEG timecodes and/or audio interlace are off. It's picking up data from the VOB.
Method 1 - Drop the file into Womble MPEG Video Wizard timeline. Export the video, but re-encode the audio to MP2.
Method 2 --- Demux with VOB Edit, remux with TMPGEnc Plus
02-05-2008, 09:40 AM
I dont have any problems with alcohol. most the errors are usually caused from corrupt windows file, ASPI update or virus
I m using the new version. I like it !!!!
02-05-2008, 10:02 AM
Tranzor Tranzor is offline
actually if you are using womble go to tools and use the gop fixer option. This will fix time code issues without reconverting any audio/video streams
02-05-2008, 02:21 PM
isnt that what I said ? lol Well what he said then
Alternative DVD recorder disc ripping tool admin Capture, Record, Transfer 0 05-15-2009 10:54 AM
Ripping DVDs - Current DVD Decrypter alternatives? benjam138 Copy DVDs, Duplicate, Replicate 7 02-24-2009 03:00 PM
Importing disc question????? MagnificentMarcus Edit Video, Audio 1 10-22-2007 03:43 PM
Re-Authoring w/o re-ripping? jpklcapp Author, Make Menus, Slideshows, Burn 3 07-13-2006 01:24 PM
