10-22-2021, 11:03 AM
Hello,
I'm planning on transferring all my family videos VHS from late 80's and early 90's to a digital format.
I've been looking around for good second hand VHS players and I have the possibility to buy one of these 2:
- Bang Olufsen VX 7000
- Panasonic NV SV-121
In your opinion, which one should I get?
10-22-2021, 11:13 AM
Those are both low-end VHS players. I'd not opt for either one. Almost all low-end VHS players are the same, crummy quality, wiggly non-TBC'd video output, chroma noise.
To be blunt, it's somewhat like asking which is better, cat poop or dog poop. But both are poop.
In PAL lands, you can get JVC/Panasonic S-VHS VCRs quite affordably. Buy it, use it, resell it. It holds value.
Remember that you'll need some sort of frame TBC.
As well as a non-junk capture card. Not Easycaps, ClearClicks, Elgato, etc.
10-22-2021, 11:45 AM
Thanks lordsmurf for your fast reply.
Panasonic NV SV-121 is in your list in the buying guide and out of all the listed VCRs, it was the only one I could find on my second hand website.
So Panasonic NV-SV 121 is good? Or I misread the list?
I will also keep researching about the other material needed. I will start the transfer process next summer, so I have time to find good equipment
10-22-2021, 11:50 AM
The NV-SV121 not a low-end VHS player, it's a SVHS deck with TBC, even listed in LS' buying guide. It's one of (or maybe the) last Panasonic SVHS PAL decks made. If you can get it for a good price, definetly go for that one. The B&O I would stay away from for digitizing.
The B&O is a Hitachi-made Hi-Fi deck which can interface with other B&O equipment. It was a higher-end model when it came out, including a flying erase head for editing, and being pretty pricey. Not aware of it being anything special for playback above other Hitachi hi-fi models from the time. Not something worth bothering with for digitizing work. It's more a thing that would be of interest for collectors of B&O gear or similar. From what I've read it's also prone to a number of issues.
10-22-2021, 11:58 AM
I removed it from the list, pending confirmation on the TBC. I'm not clear that it does, there have been posts on it. Perhaps the model number was shared? I know JVC did that a few times.
10-22-2021, 12:27 PM
This old thread would suggest it does have TBC and DNR at least, and the manual definitely notes a TBC function.
Thread |
Panasonic AG-7350 or Panasonic NV-FS200 for digitizing tapes?
simo1427 |
3 |
05-21-2018 04:19 PM |
ATI AIW 7000 series vs. 9000 series capture cards?
hysteriah |
4 |
02-09-2015 08:28 AM |
Panasonic AG-5700E vs Panasonic NV-HS1000 for transferring tapes?
tsakodim |
8 |
12-31-2014 10:00 AM |
Can my Panasonic DMR-ES10EB record Freeview channels from my Panasonic TX-L-32G20B TV
Peter_T_Ross |
Videography: Cameras, TVs and Players |
4 |
09-01-2010 05:20 AM |
DataVideo TBC-100, 1000, 3000, 5000, 7000 Time Base Corrector user manuals [DL]
lordsmurf |
Video Hardware Repair |
3 |
08-19-2010 10:14 PM |
