05-13-2022, 03:10 PM
kondwanii kondwanii is offline
I'm using the DeJitter.dll plugin for a video. I would like to know if possible can insert it on select frame numbers because I want to adjust the filter usage.
This is the script code without frame number:
DeJitter(last,jmax=40,th=80, wsyn=8, extend=true)
05-14-2022, 05:22 AM
lollo2 lollo2 is offline
The frame number is not one of its parameters, so you can't. However you can use Trim() to select the frame(s) where to apply the filter with a given set of parameters.
v1=video_org.Trim(x,y).DeJitter(last,jmax=40,th=80 , wsyn=8, extend=true)\
++video_org.Trim(z,t).DeJitter(last,jmax=40,th=60, wsyn=8, extend=true)
or use ConditionalFilter() plugin or ApplyRange() (inside Animate() plugin) or ConditionalReader() plugin where you specify the frames in a text file
The following users thank lollo2 for this useful post: kondwanii (05-14-2022)
05-14-2022, 06:57 AM
With applyrange you can:
example For:
DeJitter(last,jmax=40,th=80, wsyn=8, extend=true,uselast=false)
If you want to filter the range of frames 850 to 860
ApplyRange(850,860,"DeJitter",40,80,8,true,false)
The following users thank themaster1 for this useful post: kondwanii (05-14-2022)
avisynth, avspmod
Do different variations of PAL apply to videotape? Etcetera Videography: Cameras, TVs and Players 2 03-03-2020 09:26 PM
JVC serial numbers? jtech1 General Discussion 0 12-30-2018 07:52 PM
Help figuring out AviSynth Select structure? stevevid Restore, Filter, Improve Quality 0 09-17-2018 01:50 AM
Filter for VHS frame bounce? premiumcapture Restore, Filter, Improve Quality 3 01-04-2015 02:59 PM
Need to find out when a CD-R was created based on serial/dye numbers on disc dagardc Blank Media 14 10-31-2011 12:15 PM
