07-05-2022, 12:15 PM
Delta Delta is offline
I am compiling short trip/travel videos using video clips from multiple smartphones and I have have a few queries. Since this forum primarily deals with digitizing and restoring videos from analog sources, I am unsure if this is the right place for this topic - please advice.
1. I learnt, that like older TVs, the newer LCD/LED TVs also convert Y=16 to 235 to RGB=0 to 255 for display when played directly on TVs or when fed in from physical or software media players. This I guess is true for encoded videos tagged with color_range=tv or limited. I therefore should aim to get luma ranges between 16 and 235. Is my understanding correct here?
Do the newer TVs and players honor the tag color_range=pc/full with pixel_fmt as yuvj420p? If so, could I retain the clips in the current y = 0 to 255 range? What is the suggested option?
2. MediaInfo reports for 3 clips (Vid01-Info.txt, Vid02-Info.txt, Vid03-Info.txt) from different phones; the older vid-01.3gp (vid-01.mp4 saved as .mp4) does not have any info for color_range, color_space, color_transfer and color_primaries. The later clips vid-2 & vid-3 (vid-02.mp4 & vid-03.mp4) report values for these tags, and also report "_Original" values; What does _original represent here?
3. I believe bt470bg is used by BT.601 PAL - Why does a NTSC video use PAL color_primary; Also why is smpte170m/BT.601 and not BT.709 used for HD video?
4. Should I use the current reported values for color_range, color_space, color_transfer and color_primaries while encoding these clips?
Many thanks.
color primaries, color range, color space, color transfer
Best file format for video clips? Superstar Encode, Convert for discs 58 09-16-2021 10:21 AM
Video clips from 2 capture devices, 1 better than other? stevevid Capture, Record, Transfer 7 09-19-2018 06:34 AM
CD/DVD Care and Handling Guide from NIST/ITL kpmedia Blank Media 0 11-21-2010 12:41 PM
Best program to make a compilation DVD of video clips? Superstar Author, Make Menus, Slideshows, Burn 1 07-27-2009 03:16 AM
Video plays two clips intermittently naga Capture, Record, Transfer 1 07-07-2008 09:49 AM
