Go Back    Forum > Digital Video > Video Project Help > Author, Make Menus, Slideshows, Burn
05-20-2009, 05:20 PM
from PM...
Hello again. I really want to start authoring my own sets. Now I know you like Ulead DVD Workshop 2, I did some checking into that but I run Vista on my computer and Ulead doesn't jive too well with it. Can you make any other suggestions? Any suggestions for authoring freeware? Thanks.
I've actually not tested Ulead DVDWS2 with Vista yet, but I shall do so now. I have the 64-bit Premium version here -- which version are you using?
EDIT: Adding link to fix for using Ulead DVD Workshop 2 in Windows Vista and Windows 7 -- both x86 32-bit or x64 64-bit
See new thread at http://www.digitalFAQ.com/forum/show...shop-2126.html
Thanks. -LS
Last edited by lordsmurf; 04-15-2010 at 09:44 AM. Reason: added link to Vista + Windows 7 DVDWS fix
05-22-2009, 08:44 AM
bratac19 bratac19 is offline
Send a message via AIM to bratac19 Send a message via Yahoo to bratac19
Hello again. I'm running Windows Vista Home Premium 32BIT.
06-01-2009, 04:43 AM
I installed Ulead DVD Workshop 2 from my original disc --- not a downloaded cracked version, where most complaints originate for this software --- and was able to install it on a laptop running Windows Vista Premium 32-bit edition. I then authored a DVD, and exported it to an ISO. I was able to load the ISO with DaemonTools, and it played fine.
B&H now has DVDWS for only $99! http://www.bhphotovideo.com/c/produc...3167/KBID/4166
The only "problem" with Vista and DVDWS2 is that DVDWS2 will crash during program shutdown (after your work is saved, exported, etc) because it looks for a file -- d3drm.dll -- that is not present in Windows Vista. You can simply add this file to the C:\Windows\System32 folder, as well as the C:\Program Files\Ulead Systems\Ulead DVD Workshop 2 folder.
This won't harm you in any way, but some folks are uneasy about software crashes, for whatever reason.
I've attached the file to this post, inside a zip.
07-31-2009, 02:50 PM
randychv22 randychv22 is offline
Gracias por todo
07-31-2009, 04:49 PM
De nada.
10-04-2009, 09:40 AM
JonathanEntertainment's Avatar
JonathanEntertainment JonathanEntertainment is offline
Ahhh so that is why I have had this happen to me alot and never really looked further into it as it never really impeeded anything! Thanks
10-04-2009, 09:42 AM
Yep, nothing is impeeded, it's just slightly annoying at most.
10-04-2009, 09:51 AM
True..no arguments there..lol
How to add background music in Ulead DVD Workshop 2 Superstar Author, Make Menus, Slideshows, Burn 1 07-28-2009 07:28 PM
Ulead DVD Workshop PSD lines lordsmurf Author, Make Menus, Slideshows, Burn 3 03-14-2009 08:45 PM
Ulead Workshop 2.0 wheezer210 Author, Make Menus, Slideshows, Burn 9 01-13-2007 04:31 PM
Ulead DVD Workshop 2 angelofanimes Author, Make Menus, Slideshows, Burn 4 02-22-2006 03:21 PM
Ulead Dvd Workshop 2 help? emokid Author, Make Menus, Slideshows, Burn 12 07-11-2005 11:52 PM
