03-18-2010, 10:38 AM
continued from PM...
Hi Lordsmurf, thanks a lot for your advice and taking your time to answer my questions and providing the relevant links; much appreciated sir.
If I could just trouble your for a bit more advice; if I was to invest in software, would DVDWS2 be sufficient for all my needs? And would you advise it be worth investing in? $49 is not too bad and if it would be a lot easier to use (especially as time is short) and provide much better quality and results, then I would happily invest.
Thanks again Lordsmurf.
For the authoring portion (making menus, chapter marks, etc), then Ulead DVD Workshop 2 is the best option, absolutely.
Note that authoring is after you're done editing and making your DVD-ready MPEG files.
Think of making a scrapbook:
  • Taking photos = shooting video
  • Printing paper photos, or transferring digital photos from camera to computer = capturing video (from analog tapes), or transferring to hard drive (from digital formats)
  • Cutting photos up = editing video
  • Placing the photos in the perfect place, and gluing them down the way you want it to look; i.e., your presentation = authoring DVD
  • If your scrapbook is done on a computer, then printing it out = burning ... If your scrapbook is paper, then there is no analogy for burning.
DVDWS2 = tool for authoring
Guide for using DVDWS is here: http://www.digitalfaq.com/forum/show...-dvd-1506.html
Buy it for the current low price of $49 at http://www.bhphotovideo.com/c/produc...3167/KBID/4166
DVDWS2 - important note - prevent fuzzy menus lordsmurf Author, Make Menus, Slideshows, Burn 1 12-15-2007 05:08 AM
DVDWS2 Time of Mpg issue after changing to VideoTS Konfusion Author, Make Menus, Slideshows, Burn 10 12-14-2007 10:25 PM
Creating Chapters in Ulead DVDWS2 shadowkaos Author, Make Menus, Slideshows, Burn 2 11-10-2007 03:05 PM
Some work arounds for dvdws2 wigam Author, Make Menus, Slideshows, Burn 0 07-08-2005 03:57 AM
Question on rollover menus in dvdws2 wigam Author, Make Menus, Slideshows, Burn 4 07-07-2005 10:34 AM
