Go Back    Forum > Digital Life > Digital Devices
08-19-2012, 09:04 PM
Sossity Sossity is offline
I have an iphone 3gs, & so far have it in a black otterbox defender case, the phone is kept in a black small purse like wallet, in a dark colored mini backpack.
I ride around in an old car that does not have modern locks, so the driver insists that I have to hide my mini backpack (containing iphone) in the trunk of the car. I know the trunk is not the best place, but I dont have a choice in this matter.
I noticed the other day, after getting my pack out of the trunk, & getting my iphone out to use, that it felt warm. Would using a light colored case or otterbox iphone case help protect it against the heat? or does it really matter?
this is what the iphone is in now; http://www.amazon.com/gp/product/B00...pf_rd_i=507846
would using these protect against heat better? http://www.amazon.com/OtterBox-Defen...=pd_sim_cps_30
& http://www.amazon.com/gp/product/B00...o_cart_title_2
would the white make a difference in heat protection vs the pink?
I know that heat is not good for electronics like this, I thought I would ask about this before buying one of the pink or white ones, if the color of these would make a real difference.
08-20-2012, 12:11 AM
Color won't matter except when something is in direct sunlight. Even then, the effects are limited by other factors.
The physics of color and heat is actually somewhat interesting. It's something that I've studied quite a bit, due to the media research we do here on this site. The primary factors are absorption and reflection, but you also have to pay attention to wavelength. This is why, for example, gold DVDs are a lousy choice for archival grade media, because gold is harder to read -- poorer reflection -- than silver (or silver colored alloys) at that specific wavelength.
In other words, pick the case you think looks nice or pretty, and forget about heat.
I would pay more attention to the physical properties of the case. For example, aluminum will release heat the best, while plastic and rubber will insulate it, making it even hotter.
Phones honestly don't need extra cases. They come inside a case already.
At most, I'd add a screen protector. Maybe a couple of adhesive cloth strips on back to give better gripping.
08-22-2012, 12:52 AM
thecoalman thecoalman is offline
Sossity, get something insulated if you're worried about. Thick sock and plastic zip lock if you don't want to spend any money. Trapped air is one of the best insulators you can use hence the reason for the zip lock.
It works the exact opposite in a trunk, heat will always "move" to where it's cold though convection, conduction or radiation. Since the air in the trunk is hotter than the phone the aluminum will more efficiently conduct heat into the phone.
08-22-2012, 01:27 AM
The problem here, however, is condensation build-up.
The thick sock would hopefully absorb the created condensation. Silica gel packets could help with that, too.
And then forget the ziplock -- go straight for a small ice cooler.
Repair/bake nVidia chipset on HP laptop, create custom heat sink [IMAGES] JMP Computers 2 02-07-2012 12:40 AM
DV color space harmful to analog color quality? Verify? DeXeSs Capture, Record, Transfer 6 06-27-2010 01:48 AM
Spindle vs. Amaray case (vs. CD jewel case?) Reading Bug Blank Media 5 05-12-2009 07:37 PM
VHS copy protection removers for sale [SOLD] lordsmurf Marketplace 6 03-05-2008 12:07 PM
Heat is what kills tapes and equipment lordsmurf Blank Media 4 09-02-2005 01:12 PM
