09-23-2012, 09:02 AM
What is the best screen capture program available for Windows 7? I want one that can capture videos, video games, and VirtualBox. Basically, any program I can use on my PC, including in full screen. I tried using HyperCam but it won't install.
09-23-2012, 09:30 AM
i use WM Capture - it can capture anything that is on your screen
09-24-2012, 03:45 AM
I use the payware 1AVCapture. It works nicely.
Another good one is the freeware tool AviScreen, though it only captures in a few uncompressed formats.
I've attached the portable (no-install) version to this post. Just unRAR and use.
I'm not sure how well any of these may capture what's happening inside of a virtual machine. VirtualBox contains a video capture function, but it's command-line controlled and difficult to use. Look up "vboxheadless". I've not tried it to date myself.
There's a blog entry here, showing how complex it is: http://vmetc.com/2009/07/18/video-of...on-ubuntu-904/
I'd rather use VMWare, which has this built in and easy to use: http://www.vmware.com/support/ws5/do...g_capture.html
VMWare Workstation is payware, but has a trial: http://www.vmware.com/products/workstation/new.html
10-07-2012, 10:17 PM
i am using recordzilla. works perfectly.
10-08-2012, 01:47 AM
Do you ever have problems with recordzilla, such as not recording properly, quality issues, or frame issues?
10-08-2012, 07:04 AM
Several things to consider from that post:
- Dannylim64 is from 115.134.x.x IP space (Malaysia). That IP space is a known spammer range.
- His first post is suggesting cheap $30 payware.
- Address of company that makes Recordzilla: Softdiv Software Sdn Bhd, 216 Jalan Permai, Taman Bukit Gambier, Gelugor, Penang 11700, Malaysia
- Therefore it's likely just a spammer whoring his own software. (While we usually remove spam, I'll leave it alone this time.)
____
If you want payware, 1AVcapture works pretty well. I've used that for some online tutorials in the past. I didn't buy it, however -- it was free from GivewayoftheDay.com about a year or two ago. Get it here: http://www.pcwinsoft.com/1AVCapture
It's $60 on the site. But when you install it, it offers a 50% discount if you buy it the first day of install. So $30. My suggestion is to try it on one computer, and see if you like it during the 21-day trial. If you decide to buy it, install it on the important computer where it's needed, and take the $30 discount. (I completely hate the way software companies are dishonest about price. If you want $30, make it $30 all the time.)
