12-24-2012, 03:14 AM
bigk181 bigk181 is offline
I bought an HDTV that doesn't have a yellow video input on it. It has the audio inputs but the only video inputs it has are HDMI and component. I've been looking for an adapter that will convert the yellow video cable to component but I haven't been able to find one. I want to be able to hook up my AV devices to my HDTV. Does such a thing exist?
12-24-2012, 09:22 AM
the tvs i have (Vizio) you just plug the yellow composite cable into the green component jack
12-24-2012, 10:53 AM
if you TV doesnt allow that like my Vizio's do then you can just use a DVD recorder as a pass through.
almost all DVD recorders have AV Composite inputs and Y Pb PR Component outputs.
12-24-2012, 01:13 PM
That did the trick. It says Y/Video next to the green component jack on the TV. It must be a dual input for component and regular video. Thanks.
Looking for VHS with component for under $150 Track Capture, Record, Transfer 23 01-31-2013 12:27 AM
Capture card or DVD recorder with component inputs ? volksjager Capture, Record, Transfer 18 07-19-2012 03:01 AM
Is it possible to capture component video signal Mejnour Capture, Record, Transfer 5 01-24-2012 07:27 PM
VHS-C Camcorder vs. adapter playback NJRoadfan Restore, Filter, Improve Quality 9 01-26-2011 08:20 AM
A good switch box to add component/HDMI connections to an HDTV ? dmsinger Videography: Cameras, TVs and Players 2 09-04-2006 11:20 PM
