06-04-2013, 05:03 AM
Hi,
I was wondering if you could recommend a good, preferibly cheap DVD player.
The one you recommended before, the Philips one worked good for quite awhile until recently. It now shuts off as DVDs are playing, or the picture shuts off, then comes back on distorted. I don't know what's going on with it.
I hope things are going good for you!
This question was asked in a private message. Rather than hide our tech advice in private conversations, Site Staff will often answer PMs (from any site) here in the digitalFAQ.com forum, so that others may read and benefit from our expertise. Please continue the conversation here. Either login or join as a Free Member, and we can continue troubleshooting your video, photo or web related issue. Thanks for understanding our tech Q&A policies. |
06-04-2013, 05:05 AM
I'd go for a Blu-ray player now. Most good DVD players are gone now.
What the budget?
For about $60, there are several Samsungs.
06-04-2013, 02:39 PM
Do Blu Rays play regular DVDs also?
60 is kinda high at the moment, but is that the lowest I should go if I were to buy one?
06-04-2013, 07:42 PM
Yep!
DVD, Blu-ray, MKV, AVI, MPEG, MT2S, etc. It's far more advanced than any DVD player.
It streams Netflix, MLB.tv, Hulu/Hulu Plus, etc!
Wireless networking, USB ports, etc.
Right now, pre-cheapo era, you'll get a REALLY good Blu-ray player that should last for years.
06-04-2013, 09:13 PM
Wow, they sound good. You said there's some Samsungs, do you recommend any specific model?
Any particular model Samsung?
07-11-2013, 03:49 PM
I would not recommend Samsung. Samsung used to be good 30 years ago, but over the past 10 their quality has plummeted; I've had a few of their DVD and Blu-Ray players over the past ten years, and they've worn out within 16 months (and to replace the laser and electronics involved would've cost more than the machines were worth.
07-11-2013, 05:26 PM
My 11 year old or so Samsung DVD-S222 works fine. Its a good test unit as it tends to reject crappy media/burns. For example, it won't play burned Princo discs without skipping. Honestly the best DVD player is usually the $25 Wal-Mart special. They usually play PAL discs without a problem and can be region unlocked very easily.
07-11-2013, 07:56 PM
i use my Sony Playstation 3 - one of the best blu-ray / dvd players you will find
if i wasnt a gamer i would still probably go with a Sony blu-ray player
ive bought a couple for gifts and they are fantastic
07-17-2013, 09:41 PM
Samsung is like Sony. It has lots of things branded by them, but only some are actually manufactured by them.
The Blu-ray players, TVs, and computers tablets (like iPad) are three that are. And all are good.
Even Sony rebrands a lot of Samsung parts these days.
Samsung makes their own optical drives , which is why the player are good. Samsung is second only to Pioneer now!
This is one of the best right now: http://www.amazon.com/gp/product/B00...&tag=thdifa-20
$88 sold by Adorama on Amazon.
I bought two. These were $100+ each before Christmas 2012.
If you want cheaper, get this: http://www.amazon.com/gp/product/B00...&tag=thdifa-20
It's only $70. I bought one.
I had gotten these for Christmas last year. (Never got to give them out, of course, being in the hospital and all.)
They got them this year, and they all love them. Great for streaming with a DNLA, or weatching formats on drives. Almost ANY format!
