06-05-2013, 07:51 AM
naripeddi naripeddi is offline
I have 100's of WAV files that I extracted from DV AVI files in VirtualDub (Save as WAV).
I would like to convert all those WAV files into MP3 format so I can listen to them on mobile on the go.
Is there a free program that can do this?
Regards
Not much replies from site staff these days???
06-11-2013, 08:33 PM
tomswift tomswift is offline
Have you tried iTunes or Windows Media Player?
06-11-2013, 10:11 PM
Site Staff has a mix of projects, systems overhauls (computers were 4-5 years old), and vacations right now. It's temporary.
Audacity can do this. But it's not batched.
Besweet still works, for batching.
06-11-2013, 11:47 PM
I do not have iTunes since I do not own any Apple product. Never bothered to install it, thinking it might ask for Apple ID, Password, an Apple device to be connected...etc. Windows Media Player would only convert to MP3 when it is in 'Rip' mode from a CD, not from hard drive.
regards
Ok.
Tried Audacity, it is able to accept multiple WAV files (File --> Open Multiple or something like that) as input, and then export as MP3 with LAME add-in. Tested it successfully for 2 files in a batch, worked fine. But when I loaded about 100 WAV files, it is taking forever to generate the waveforms for all of them and finally system hangs. [/quote]
Can Besweet do WAV to MP3 conversion in batch?
06-13-2013, 03:15 PM
Besweet can batch that, yes.
In fact, so can Nero! I used Nero last time. Yes, Nero the burning software. (I have v6 installed.)
If you're planning to burn these to CD/DVD/Blu-ray, you can also use BurnAware Free.
Admittedly, it's been at least a year since I converted WAV to MP3. I buy MP3's now from Amazon, so they're already converted.
06-13-2013, 10:34 PM
Great. Thanks LS.
regards
How to deinterlace MP4 video + batch processing? segen77 Restore, Filter, Improve Quality 3 02-13-2014 11:43 AM
Which color profile to use, when batch processing photos for the web? Sossity Photo Processing, Scanning & Printing 1 11-07-2012 05:42 AM
Problems with Taiyo Yuden - bad batch of media? crescent.cal Blank Media 5 12-31-2008 03:46 PM
Can you recommend a batch image resizer? mlaviolette Encode, Convert for discs 1 10-14-2006 12:08 PM
