04-03-2014, 04:56 PM
videonut videonut is offline
Looking for an ATI all in wonder card PCI.
07-21-2014, 01:09 AM
Were you ever able to track one down?
These show up on eBay from time to time, but beware of card-only auctions -- those are useless. At minimum, it needs to come with its original purple break-out box. There's two kinds of purple breakout dongles, and the newer AGP and PCIe ones do not fit the older PCI cards (or the AGP 128 Pro).
Why not use an AGP cards?
07-21-2014, 08:28 AM
the only good PCI card is the 7500 VE - sabre pc still has some brand new last time i checked
actually you dont need the breakout cables if you only want to capture S-Video
(breakout is required for the later cards that have square plug)
if you break the little plastic tab off a normal S-Video cable it plugs right in the pin-outs are correct.
you do need the breakout cables for composite
i tested this with 7500, 9000pro 9200 and 9700 and it works fine.
here is mine:
ATI MMC version 8.8 best for AIW 9600 card ? pete Capture, Record, Transfer 1 03-21-2012 02:45 PM
SignVideo PA100 (PAL version) wanted astro Marketplace 1 10-18-2010 05:11 AM
Tsunami DVD Author Pro - New Version allaboutduncan Author, Make Menus, Slideshows, Burn 6 08-30-2005 02:53 PM
DataVideo 100 or 1000? Which TBC version? manthing Restore, Filter, Improve Quality 4 07-13-2005 03:54 AM
