06-14-2014, 06:05 PM
jedi55 jedi55 is offline
Hi,
Is there a software package that smart renders mpeg-2, wmv, avi, mp4 and mov frame accurately?
All I want to do is trim and join stuff.
Many thanks
06-14-2014, 06:30 PM
i know Powerdirector does mpeg-2 - not sure if it does the others
06-14-2014, 10:38 PM
TMPGenc Smart Renderer v4. You might also take a look at VideoReDo TV Suite. If your sources are substandard or copy protected, forget it.
07-20-2014, 06:01 AM
I use TMPGenc Smart Renderer v4 all the time on H.264 (MKV,MP4) files.
And then Womble for MPEG-2.
I'm not aware of anything that works this way on Quicktime MOV or WMV.
"AVI" is just a container.
Capturing 15mbps MPEG-2 in ATI MMC, have dropped frames? volksjager Capture, Record, Transfer 3 06-12-2014 03:25 PM
Compression with MMC ATI, P frames and B frames for MPEG-2 ? John Capture, Record, Transfer 1 08-20-2011 10:15 PM
Smart phones with good internet access, and pay as you go? Sossity Digital Devices 2 07-27-2011 08:10 PM
Problem with MPEG video dropping frames kabal2000 Capture, Record, Transfer 9 08-02-2010 12:39 AM
Edit an mpeg without re-rendering dmsinger Encode, Convert for discs 4 03-16-2005 12:10 PM
