10-01-2014, 12:24 AM
kalemvar kalemvar is offline
Hello everyone.
Just before beginning I'm referring to this guide : http://www.digitalfaq.com/guides/vid...t-pal-ntsc.htm
I've done every steps from the guide without any problem but at the end the video is little bit out of sync. I tried many things with Goldwave without any success until I noticed one thing, after de-multiplex in TMPGEnc. the video file is 0:41:07 long and the .ac3 file is 0:41:05 long. I think this is where the problem is.
Is it normal? Am I doing something wrong ?
Eric
PAL tape conversion to NTSC Mejnour Project Planning, Workflows 9 06-23-2015 04:44 PM
PAL to NTSC conversion reduces the file size? ohsnapimaninja Encode, Convert for discs 1 07-27-2014 07:36 AM
How do I fix out of sync audio? Superstar Edit Video, Audio 12 09-28-2013 01:41 PM
PAL/NTSC Conversion Guide updates + de-blur restoration (add Avisynth use) admin Restore, Filter, Improve Quality 2 02-19-2011 11:42 AM
PAL to NTSC conversion of audio using Goldwave Knight$peed Encode, Convert for discs 7 04-22-2009 06:08 AM
