10-22-2005, 05:17 AM
Tom_n_Jonna Tom_n_Jonna is offline
Hi guys...
I extracted an episode from a DVD using DVD Decrypter in IFO mode; the episode has bad audio, but good video. I have another copy of the same episode I've also extracted in the same way, but this one has bad video with good audio. I'd like to take the audio from one and marry it with the video of the other.
How would I do this?
Tks...Tom
Cheers...Tom
10-22-2005, 06:17 AM
Tricky issue. Are you sure the running time on both versions is the same. And that any commercial breaks in the middle is the same?
You may have to demux something like this, convert the video to AVI, cnovert the audio to WAV, and drop the files on the Adobe Premiere timeline and try to line up audio by chunks. And then export the audio timeline, no need to re-encode the good video. It's AVI solely for better preview playback support in Premiere, MPEG doesn't work so hot in an NLE.
10-23-2005, 04:34 AM
What about this...the bad audio part is just the last few seconds of the clip. It seems it would be easier to demux and match just that portion.
So, what do I use to demux that will preserve the sound (AC3 I think)?
Tom
10-23-2005, 09:45 AM
You can't preserve the audio. Extract it out to WAV. Leave it as WAV if you can. If not, encode the newer clip to an AC3 again, preferably 384k bitrate if you can.
TMPGEnc can demux MPEG files, using the MPEG TOOLS from the FILE menu.
Converting a 12GB Mpeg to a 4GB Mpeg Konfusion Encode, Convert for discs 1 09-03-2007 06:06 AM
MPEG-2 vs. MPEG-2 DVD in MMC TV Capture JimGorsline Capture, Record, Transfer 4 07-09-2004 02:20 AM
Audio editing using Womble MPEG Video Wiz jrnyhead Encode, Convert for discs 3 02-08-2004 12:40 PM
