03-27-2015, 04:06 PM
pickle pickle is offline
Just wondering if the panasonic NV-HS800A is a good unit for converting VHS to DV?
I can't find any info that says it has TBC.
It has a picture sharpen slider on the front but that's about all the useful editing parts i can see.
Thanks.
03-27-2015, 05:16 PM
Quasipal has owned this model before.
PM him, and ask that he post here. Let's all find out if this unit should be added to the recommended list.
03-28-2015, 04:23 AM
Quasipal Quasipal is offline
Yes I have owned this unit - I'll share what I know. Firstly this model ran concurrently with the more well known HS1000 model so 1995-1997/8. Both use identical heads and mechanisms (K Deck) and as far as I can see the video circuitry is almost identical too. The 1000 offers extra features, namely assemble edit and time base correction. In normal play mode both look the same on screen with both having the soft to sharp slider and edit selection for raw playback. So to sum up the HS800 is fully worthy of use in the role of video transfer with the caveat that it does not have TBC. If you do as I did and run it through a Panasonic DVD recorder with internal TBC this may not be so important but if you are running directly to the video capture card then you may well miss the TBC that the HS1000 offers.
To add, I have seen both of these models with worn heads quite often which has a negative impact on the picture and hifi sound. Also both models really hate TDK Pro S-VHS tape - it clogs the heads (don't know why this is) and neither are great options for really ratty old tapes as they don't mask dropouts as well as some other decks.
I'd pay £80 for an HS800 in good condition and £130 for a HS1000 in the same state.
Hope this helps.
04-04-2015, 08:15 AM
So the HS-800A is a non-TBC unit? That'd make it useless as far as I'm concerned. I'd rather find the HS-1000.
04-04-2015, 09:24 AM
Hi Lordsmurf - yes you are correct - the HS800 has no TBC. The only PAL consumer / semi-pro VCR's to have TBC are the following:
FS200
HS1000
HS950
HS960
HS860
HS930
These are in the order of production.
Panasonic AG-W1 produces scrambled picture with no color, worth repair? autephex Video Hardware Repair 6 11-13-2014 07:06 AM
Panasonic AG 1960 Worth Repair? GreenAcres Video Hardware Repair 1 02-05-2014 05:01 PM
Advice on buying a VCR - JVC vs Panasonic Tuco Capture, Record, Transfer 3 02-10-2012 06:44 AM
Power surge protectors - worth buying? manthing Videography: Cameras, TVs and Players 2 03-07-2011 10:15 AM
Verbatim - worth it? Bill Downing Blank Media 3 01-13-2011 01:11 PM
