10-31-2015, 09:43 AM
joer007 joer007 is offline
I've had a batch of DVD-R that do not burn - error code that the burn was not successful. Are there programs to allow testing of DVD quality before trying to burn?
01-04-2016, 08:20 AM
No. DVD have to be burned or pressed to be tested.
If none of them burn, it could be an indication of the DVD burned dying. Or possibly a compatibility issue.
What is the media ID and brand of the disc. (Give both.)
01-04-2016, 08:28 AM
The discs were Verbatim. After a lot of trying, I reduced the burn speed to 4x and have no further problems. Thanks for getting back to me.
01-04-2016, 08:40 AM
I still would like to know the media.
Verbatim brand now uses some low-end CMC junk, and not just the quality Mitsubishi discs from their parent company.
01-04-2016, 08:53 AM
All I can tell you is that these were Verbatim 4.7, 16x speed, AZO DVD-R that I got from Amazon.
01-04-2016, 08:41 PM
Anything on the packaging, such as a part number or where they were made?
Can you check the Manufacturer ID on the discs? DVD Identifier or Nero Media Info are a couple free tools that can give that information.
I have some Verbatim DataLifePlusDVD+R DL, P/N 98319, that are labeled as "made in United Arab Emirates" with a MKM003 media ID.
01-05-2016, 10:21 AM
Mfg. is Mitsubishi Chemical Co. ID is 03RG20
Best blank DVDs for burning HD video? Windows installers? ChimaeraJ Blank Media 7 12-26-2015 08:55 AM
M-Disc blank DVD media ... Any testing done? jbd5010 Blank Media 5 07-29-2014 08:44 AM
Problem burning EP blank DVDs on Panasonic tlonnie Blank Media 12 01-08-2013 04:58 PM
Problem burning Memorex blank DVDs lasedan Blank Media 2 07-21-2011 01:35 PM
DVD Burning Errors, Cyclic Redundancy Check and burning freezes rmehta2 Copy DVDs, Duplicate, Replicate 7 07-13-2005 12:34 PM
