11-28-2015, 02:01 PM
mdubec mdubec is offline
Hi,
I read through the "SoundForge Audio Filter Presets Pack" posted by admin that last had an update in 2013. I've tried many different things but I still can't install the Preset Package. I'm using SoundForge 10.0. In the Preset Manager is says that the Plug-ins are not installed. See photo. I did research on how to install them but the first thing it says to do is to choose the Preset Destination. But it says none are installed. See photo.
Any help would be appreciated!
Thanks!
Mike
11-28-2015, 06:23 PM
Goldwingfahrer's Avatar
Remembered
Possibly to find what
http://www.digitalfaq.com/forum/vide...io-filter.html
11-28-2015, 07:00 PM
Yes, that is what I originally read. It doesn't say anything about my situation.
11-28-2015, 07:05 PM
You drag the top to the bottom.
See the top area that says "Prese" and is cut off in your image? Highlight the stuff in the top-rightwindow.
Drag it to the "System Presets" bottom-left window.
I have the SoundForge 2015 updates. I need to add them when my main system is back online.
11-28-2015, 08:48 PM
Yep, did that. Then I close the program as directed in the previous thread. I open it back up and it says "not installed 000" as it shows in the picture.
11-28-2015, 08:52 PM
It's confirmed to work with Windows XP/Vista/7 and Sound Forge 6-10. And it'll probably work with Win8+ and SF11+.
The error appears to be local for you.
11-29-2015, 06:38 AM
Remembered
Hello lordsmurf
Accomplishing this is enormously complicated.
I tried it once under Win7, since I need 2 weeks to I have tried and adjusted everything.
Here are some pictures
Since I love Wavelab 6:11 because I can adjust several plugins side by side simultaneously.
Images appear still too small in the Forum
Here in original size
www.ww-consulting.ch/DL/SForge.zip
Installing Plesk 12 = UGH! kpmedia Web Hosting 0 08-19-2014 11:37 PM
How do I use Sound Forge preset filters? Tafflad Restore, Filter, Improve Quality 5 11-03-2013 09:56 AM
Soundforge preset pack install issues Tafflad Edit Video, Audio 3 11-02-2013 09:20 AM
Installing ATI AIW Card Dewey Capture, Record, Transfer 3 04-14-2009 09:04 PM
MMC Preset Times lantern Capture, Record, Transfer 2 08-05-2004 08:16 AM
